Oil leak when hot
Old Oct 4, 2017 | 06:57 AM
TwoBlue02's Avatar
TwoBlue02
Default Oil leak when hot
2010 Ultra has a small oil leak ( a few drips) after I ride and the engine is hot. Soon as it cools no problem. I replaced the gasket on the drain plug at my last oil change and have made sure it is properly tightened. I can't see under the bike enough to see what the problem is but it is toward the front part of the engine.
Any ideas on what it is and what the fix is?
Old Oct 4, 2017 | 07:19 AM
RK_Classic's Avatar
RK_Classic
Check were your stator wires comes out of the inner primary, That rubber grommet is famous for leaking. If that is the source you can either replace your stator or use some black gasket maker and run a small bead under the lip of the grommet. It worked very well on mine 2 yrs ago.
rk classic
stmcmann
Jul 6, 2019 01:04 AM
1flhtk4me
Jun 1, 2018 07:46 AM
Dirt Bagger
Nov 19, 2013 10:05 AM
sargek
Nov 1, 2011 02:01 PM
arthurn
Exhaust System Topics
May 10, 2010 08:38 PM
