Here's my dyno sheet. The info at the bottom is incorrect, I'm not running a 2-1, it's a fuel moto XXX headpipe with their crossover and E-series mufflers. The little curleque around 4200 rpm is the clutch slipping. I just replaced that today with a Bernett extra plate set, no slip no more.
Roomer: How does the Barnett extra plate set differ from the Barnett heavy duty clutch spring? I had the their heavy duty clutch spring, and it played havoc on everything around the clutch plates themselves. Curious about the difference.
I doubt you'll make those numbers with a slipping clutch. Granted they are STD but still... A slipping clutch would be a dip. This shop's dyno possibly does that to every graph.
If you're going to port the heads, talk to a head porter. I would think you'd be looking at a different cam than the 222 if you have better flowing heads. Unless it's just very basic headwork you're after.
Can I ask why you're looking at holding off going big bore?
Originally Posted by rhuff
Let's see....... He's asking us instead of talking to his possible head porter. So, genius, hence the suggestion as he's talking to US.
And the 222 likely won't utilize the added flow of ported heads.
Reading AND comprehension seem to be a struggle for you.
Boy nothing get's by you does it?
You're just as sharp as a tack.
Being a condescendent ******* is easy for you though isn't it?
So what is your question?
You want to add cams but haven't?
You want to have the heads ported but haven't?
You want to know how your motor will be after that if you do these things?
That it?
Hmmmmm...... who is the *******? And it's "condescending."
If you don't like being called out for being an *******, condescending, and wrong, then do be those 3 things.
OP had a question and you seemed to have missed it because you were being pompous. Then you were wrong and I called you out on being pompous and your inability to follow logical lines of questions; So now you cry about me correcting you and you feel as if I'm condescending. Um....okay. Sorry you don't like being wrong.
As far as the difference between the extra plate set and the heavy duty clutch diaphragm , the set has more surface area for grip not just more pressure on the discs as with the spring alone. I have the harley police bike diaphragm in mine, a bit more pressure but not as stiff to pull as the heavy duty. As far as the dyno sheet, I was there when it was done. There were several pulls done while adjusting the tune without the loop showing. They were from 96-99 hp. I heard the little slip on that run. It was very short duration, fraction of a second.
Suppose it could have, however my clutch would slip slightly under full power in 5th gear and after changing to 6th gear under full power. After I changed the clutch yesterday it really hooks hard now.
I didn't miss ****.
That was your interpretation and you missed it.
Riddle me this;
If someone has a 100-HP SG, what is it that he needs to know from us, smart guy? If anything maybe we need to know from him.
Something seem just a bit illogical to you about that?
No crying here, maybe on your part though but you probably still can't figure that out, right?
I didn't miss ****.
Riddle me this; If someone has a 100-HP SG, what is it that he needs to know from us, smart guy? If anything maybe we need to know from him.
You're the one who initiated.
How to get more HP, and more torque out of his bike at high altitude like he clearly stated? Maybe? It wasn't, and isn't an unreasonable question, even if "more" is of no interest to you as seems apparent in your stated numbers noted in your signature line.
I'm always looking for bigger numbers, money included(pun intended).
Right now AEB my sig. I have a 96 motor but purchased a very nice set of 103 heads from a site member, bought the harness and am looking to get a 107 kit for it and will have to re-do everything all over again, cam's included.
Going with 57H's.
