Dot 4/5 and Calipers
Old Jun 13, 2007 | 11:21 PM
Bryan1724's Avatar
Bryan1724
Default Dot 4/5 and Calipers
I'm going to switch out my front end to a 2000 and up. Bigger axle, more wheel choices, and the main reason better brakes. I'm picking up a set of take off front calipersfrom a forum member off his 07. My 99 takes Dot 5 and the 07's went back to Dot 4. Since the caliper #'s haven't changed I'm guessing there's not anydifference with the calipers just the brake fluid? Thanks, much, Bryan
Old Jun 14, 2007 | 01:33 AM
Biggzed's Avatar
Biggzed
Default RE: Dot 4/5 and Calipers
Bryan - DOT 4 and DOT 5 are not compatible. You probably already knew this.
You're going to have to take apart, flush, and replace all seals in either the new calipers, or the master cylinder and brake lines that are already on your bike.
Personally, I would rather dis-assemble the calipers for 4 reasons:
1) They are not already on your bike
2) They seem easier to take apart and put back together than a master cylinder
3) You won't have to worry about flushing the brake lines
4) DOT 5 is supposed to be better (higher boiling point) than DOT 4
I just went through this same thing with the new Jay Brake 6 piston. The Jaybrake specified DOT 5. I called them and they said since it had never been installed before, DOT 4 would be ok.
Hope this helps.
Old Jun 14, 2007 | 01:41 AM
Bryan1724's Avatar
Bryan1724
Yeah it does help. I knew I'd have to prob flushout themnew calipers I'm getting from Biggzed [sm=icon_rofl.gif]Sorry couldn't resit. My only concern was the rubber in the calipers being different for some Dumb, Odd reason for the 4 and 5 fluid. I really didn't think that they would be but hey, you never know. I'm def sticking with the DOT 5 just wanted to double check to make sure what I thought was right, actually was. Did I read somewhere where denatured alcohol was a good choice to use for the flush, or do i just have alcohol on the brain? [sm=icon_guiness.gif]
Old Jun 14, 2007 | 01:44 AM
voodoodrug's Avatar
voodoodrug
Seems that dot 5 needs more maintnance in the long run but could just be my imagination. Seems like you have to be ontop of replacing fluid and master cylinder rebuilt more often? And how much "boiling" is there really goinon? Somethin to think about?
Old Jun 14, 2007 | 01:50 AM
Bryan1724's Avatar
Bryan1724
ORIGINAL: voodoodrug
DOT 5 does not absorb moisture, that's what i like about it. Moisture in iron calipers = rust and pitting. As far as maintenance, not sure it's any more than DOT 4, but hey I could be wrong and have been before. My 99 has all but 50,000 thousand on it and the master cylinder, and calipers are fine. No leaks no problems. I am curious as to why HD went backwards to DOT 4 though. [&:]
Old Jun 14, 2007 | 02:01 AM
voodoodrug's Avatar
voodoodrug
Got a letter or more like a flyer from moco about that but maybe someone with more knowledge could better answer why they changed[sm=groupwave.gif]
Old Jun 14, 2007 | 03:17 AM
Biggzed's Avatar
Biggzed
ORIGINAL: Bryan1724
I was told to use propilic alcohol. I've never heard of it. I would think any automotive parts solvent should work. I think the key is replacing all the rubber seals.
Old Jun 14, 2007 | 09:43 AM
Moe55's Avatar
Moe55
From what Iwas toldthey went back to Dot 4 because they were having someproblems with Dot 5 on ABS police bikes. Changing fluid solved the problem.
Old Jun 14, 2007 | 10:03 AM
sleepneagle's Avatar
sleepneagle
if you have dot 5 stay with it. if you switch to dot 4, rebuild the calipers and master.
fxdx1985
Feb 24, 2017 11:02 AM
Ruggs59
EVO
33
Nov 17, 2015 12:53 PM
miandsh2000
Wheels/Tires
Aug 4, 2010 01:52 PM
JR-Boston
Jun 7, 2010 06:52 PM
bigjako
Oct 18, 2007 05:30 PM
