oil filter
Old Nov 3, 2017 | 04:53 PM
hardheaded's Avatar
hardheaded
pipe wrench and cheater pipe and then stand on it. it will never come loose again.
Old Nov 3, 2017 | 05:00 PM
Screamin beagle's Avatar
Screamin beagle
Somebody has to ask ...what kind of oil are you using?...sorry lol
Old Nov 4, 2017 | 08:16 AM
FL-kruzen's Avatar
FL-kruzen
Sounds like the thread adaptor is the issue...
Old Nov 4, 2017 | 08:59 AM
lionsm13's Avatar
lionsm13
Put a new adapter plate on. They're pretty cheap.
Old Nov 4, 2017 | 10:04 AM
JAMESAK51's Avatar
JAMESAK51
I agree with the thread adapter. I've never had a problem with it on a Harley but I did have one loosen up on a smaller engine. The filter was loosening up and leaking until I tightened it up. With the filter off make sure you can't turn it by hand. If you can turn it tighten it up and then try it with a new filter. You could also spin it out and clean the threads and try some Loctite.
Old Nov 4, 2017 | 08:16 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Welcome to the forum, seems you've stumped the panel.
Old Nov 4, 2017 | 11:49 PM
t. sawyer's Avatar
t. sawyer
something smells funny here to me.
kroozeabout.
Old Nov 5, 2017 | 03:28 AM
djkolp's Avatar
djkolp
1st and only post. Oil filter won't stay on even with red loctite? Who the hell would use loctite on an oil filter? Oh yea, Trolls do.
Old Nov 5, 2017 | 06:25 AM
santajim's Avatar
santajim
Make sure you rub a little oil on the rubber gasket that will help it seal; and come off. I have been a mechanic all my life and have never seen a filter back off, more the opposite when you go to take them off the gasket has swelled from heat and are harder to take off.
Old Nov 5, 2017 | 08:04 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Hook, line and sinker...
