oil filter
Old Nov 3, 2017 | 11:48 AM
Brucet's Avatar
Brucet
Stage I
Default oil filter
2008 Electra glide screaming Eagle CVO.
Oil filter won't stay tight. Have tried locktite blue and red. After about 400 miles it becomes loose. Have checked to make sure the old rubber gasket wasn't stuck on. Out of Ideas on what the problem could be. This has happened with the last 3 filters.
Old Nov 3, 2017 | 11:52 AM
ChunkChunkChicken's Avatar
ChunkChunkChicken
Oooook let's give it to him boys! LOL
Old Nov 3, 2017 | 11:54 AM
skydude426's Avatar
skydude426
Put it on tighter?
Sent from my iPad using IB AutoGroup
Old Nov 3, 2017 | 12:17 PM
nobodyknowsme's Avatar
nobodyknowsme
No use...
Old Nov 3, 2017 | 12:20 PM
TriGeezer's Avatar
TriGeezer
Huh?? Red locktite?
Sounds like the nut on the seat is loose.
Old Nov 3, 2017 | 01:22 PM
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
I'd start by getting a new filter. Could well be off-spec with regards to the threads, letting it slip on the threads of the adaptor.
I'd also look at the adapter it screws into. The part is cheap, if I had any doubts about it, I'd replace it. Part number 26041-05a I believe.
When I remounted the filter I'd use a sharpie or marker and draw a small line across the filter and the mount, so I could see if it was rotating when coming loose, or popping loose by skipping down the threads.
I'd consider using a hose clamp on the filter and some wire to safety wire the filter in place if it was somehow mysteriously unthreading itself.
Old Nov 3, 2017 | 02:10 PM
gipper's Avatar
gipper
[QUOTE=foxtrapper;16794665]I'd start by getting a new filter. Could well be off-spec with regards to the threads, letting it slip on the threads of the adaptor.
Both of these two solutions are exactly what I'd do. I've never heard of this happening on a car or a motorcycle, though I suppose it can happen. The loctite solution is definitely not the correct one though, that's for sure.
Old Nov 3, 2017 | 03:57 PM
nobodyknowsme
Tell us about what filter type/brand you are using. I myself prefer K&N as I feel they are at least as good if not better than HD plus can usually be had cheaper from local auto parts store. I also prefer the nut (17MM I believe) on the end thus not having to get it off with an oil filter wrench which can be hateful, especially if one has a chrome voltage regulator cover.
Old Nov 3, 2017 | 04:15 PM
Eric Moore's Avatar
Eric Moore
Something isn't right .. I have never had a oil filter come lose.. never.. I have several bikes with high miles.. one with 76 k on it.. you can get a k&n filter along with the hex it has a hole to safety wire it so it can't rotate.. But as others have note something else is causing this
Old Nov 3, 2017 | 04:27 PM
r0de_runr's Avatar
r0de_runr
Use a K&N filter with the nut on the end. Hand tight then another 1/4 to 1/2 turn. Ought to do it.
