oil filter
Old Nov 5, 2017 | 08:08 AM
RollaMo's Avatar
RollaMo
Originally Posted by djkolp
1st and only post. Oil filter won't stay on even with red loctite? Who the hell would use loctite on an oil filter? Oh yea, Trolls do.
Yep, lots of that going on these days.
Old Nov 5, 2017 | 09:46 AM
Boomer1143's Avatar
Boomer1143
K&N filter with safety wire through the nut. It won't back off then.
Old Nov 5, 2017 | 10:18 AM
Cygnusx51's Avatar
Cygnusx51
What color filter are you using? Red locktite works best on red parts. I’d try painting the filter before you start replacing things.
Old Nov 5, 2017 | 10:38 AM
hardheaded's Avatar
hardheaded
the earlier adapters up until mid 2013 did come loose once in awhile. leaked between the engine case and the adapter, not the filter. if this is the case you can take a bolt (i think it was a 7/16 ) and double nut it and then tighten it up. also the little plugs that are in the earlier adapters are known for leaking to. if you buy a new adapter be sure and get the mid 13 and newer one, much better design.
nhjeffs
Aug 22, 2018 06:01 AM
TheMarshal
Sep 29, 2015 08:31 AM
dwayne u
EVO
11
May 1, 2012 12:19 PM
rgustashaw
May 19, 2009 08:14 PM
vtxed
May 14, 2007 02:48 PM
