Re installing forks?
Old Nov 4, 2017 | 05:47 PM
liquidr1's Avatar
liquidr1
Default Re installing forks?
Am i missing something? How do you make sure the for tubes are aligned properly when you slide them back in the fork clamps
Old Nov 4, 2017 | 05:55 PM
Teal's Avatar
Teal
Are you referring to the vertical height? Assuming you are, you basically just need to measure the height protuding above the top clamp and make sure it is the same on both sides. The factory height is usually about 1/8" proud.
Old Nov 4, 2017 | 05:58 PM
Musician's Avatar
Musician
Default fork alignment
First, what do you mean by fork alignment? The upper sections will be aligned by the upper and lower mounts, automatically. They will only fit one way. As for the lowers, make sure you have them identified as right, or left. Look at the caliper mounts. They go on the back of the fork, so that makes the positioning possible. Mark with a "R", or "L", before removal, to simplify. You really should be consulting your factory manual before even removing the forks. If you are talking about how far up the clamp the fork should be, just enough so that the fork cap can be torqued properly without interference. Again, CONSULT YOUR MANUAL! All this information is covered quite well, with pictures. Good luck.
Old Nov 4, 2017 | 06:24 PM
liquidr1's Avatar
liquidr1
I mean rotationally. How do you make sure the are aligned properly so that the axle goes straight through and the wheel tracks straight
Old Nov 4, 2017 | 06:32 PM
TSheff's Avatar
TSheff
You know they can rotate???
Old Nov 4, 2017 | 06:33 PM
CSMHOG's Avatar
CSMHOG
Seriously, turn the lower fork (left and right) until the axle slides through ... it’s not rocket science.
Old Nov 4, 2017 | 06:44 PM
liquidr1's Avatar
liquidr1
I guess im overthinking it.
Old Nov 4, 2017 | 07:06 PM
Notgrownup's Avatar
Notgrownup
Way over...
Old Nov 4, 2017 | 07:07 PM
TSheff's Avatar
TSheff
Curious - why were the tubes out??
Old Nov 4, 2017 | 07:41 PM
liquidr1's Avatar
liquidr1
They arnt out. Just prepping my thoughts for when install for cartridges
