Help with 110ci upgrade.
Old Nov 10, 2017 | 12:14 PM
Laybac101's Avatar
Laybac101
6th Gear
Default Help with 110ci upgrade.
So I am looking to pump up my Street Glide to a 110ci.
Current stuff on bike: Arlen Ness Stage 1 Big Air Sucker, Freedom Performance True Dual headers, Freedom Performance Slip-ons, and a V&H Fuel Pack 3 tuner. No previous motor work done.
So far this is on the purchase order I have:
1. S&S Super StockŽ 89cc Cylinder Head Kit - Item #: 106-3240
2. S&S 110" Power Package with 585 Easy StartŽ Gear Drive Cams - Item #: 330-0583.
I am not sure if it is lack of knowledge or I am not searching the right areas but I am not sure if I will need a bigger throttle body and or bigger fuel injectors. Also not sure what else I may need to ensure this job is done right (gaskets, other parts)
Old Nov 10, 2017 | 12:21 PM
KCFLHRC's Avatar
KCFLHRC
Looks to me like you can buy a kit that comes with everything you will need
https://www.sscycle.com/products/110...wrinkle-black/
Old Nov 10, 2017 | 12:23 PM
Laybac101's Avatar
Laybac101
6th Gear
That is on the to buy list, along with new 89cc heads. I am not sure if I will need a bigger throttle body and or bigger fuel injectors with the combo of buying these two kits.
Old Nov 10, 2017 | 01:43 PM
Laybac101's Avatar
Laybac101
6th Gear
Maybe i will get the kits and install and she how she runs. I can upgrade the RB and Injectors pretty easily later.
Old Nov 10, 2017 | 03:30 PM
NMfxdf's Avatar
NMfxdf
I was interested about this as well, I am guessing if you do a 110 kit, then a dyno is a must right? I would be surprised if the FP3 allows for that.
Old Nov 10, 2017 | 03:41 PM
Laybac101's Avatar
Laybac101
6th Gear
Just got word back from S&S. New TB is not required but bigger injectors are; 5.3 or larger. They also stated that a rocker box gasket kit is required.
Old Nov 10, 2017 | 04:34 PM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Your stock TB will be fine like S&S has already mentioned.
Since you will be needing a proper dyno tune, check with your Turner. But I would choose a TTS MasterTune Turner as my first choice, Power Vision as my second choice for a tuning device.
Good luck and Enjoy!
YB
Old Nov 10, 2017 | 04:50 PM
Laybac101's Avatar
Laybac101
6th Gear
YB
Thank you but already have the FP3. I have seen/heard that the FP3 is able to tune with this setup. I will need to check with local Dyno shop to see if they are familiar with FP3 tho. thank you again.
Old Nov 10, 2017 | 08:29 PM
talkingrock's Avatar
talkingrock
the FP3 will work its finding a dyno man that will have the knowledge to adjust the map will be the problem
Old Nov 11, 2017 | 11:52 AM
oldhippie's Avatar
oldhippie
You'll need to beef up the clutch.
