Performance baggers
Old Mar 12, 2023 | 11:39 PM
  #1751
Performancebagger2022's Avatar
5th Gear
Aluminum side covers. Anybody tried Nasty Hog Rebel kit? Any comments?
Old Mar 15, 2023 | 06:54 PM
  #1752
CryingJoker's Avatar
CryingJoker
Well upon changing rear tire the other day I realized rear brakes were due for changing and I did galfer rotors and pads up front I decided to add a few more goodies.
Old Mar 16, 2023 | 06:29 PM
  #1753
Kfuller1212's Avatar
Kfuller1212
Do you get any weird nosies from the front galfers? I put the cubiqs on my 2020 road glide and they sound like a pack of Cicadas chasing me... galfer says this is normal, just air going over the blades..... the harder u apply the brakes the louder it becomes. U can even hear it a little with no brake.
Old Mar 16, 2023 | 06:48 PM
  #1754
CryingJoker
No I haven't experienced that. I did offset mount mine though where the blades aren't in the same orientation on both sides that might have something to do with it.
Old Mar 16, 2023 | 06:52 PM
  #1755
Kfuller1212
Ya i may have to try that. Don't know with the cubiqs if it will make much of a difference. They are not cut like the wave rotors. I could be wrong tho. Did u just rotate them 180?
Old Mar 16, 2023 | 07:23 PM
  #1756
CryingJoker
True not sure either. All I did was rotate so that when you look across the wheel from the side they aren't the exact same. Basically like imagine looking at 2 sprockets stacked one tooth off so it looks like they alternate
Old Mar 17, 2023 | 05:38 AM
  #1757
Kfuller1212
Thanks I will give that a try and see if it helps. The noise is killing me... they do stop way better than stock rotors, I will give them that. But if I have to hear this everytime I stop they will have to go.... I can hear it over the aftermarket stereo with 800 watt amp... just to give it some context.
Old Mar 17, 2023 | 12:16 PM
  #1758
Puglia10's Avatar
Puglia10
Nature of the beast with floating rotors, my EBC do it as well. Doesnt bother me since they stop well.
Old Mar 17, 2023 | 12:21 PM
  #1759
Darkstar_XIII's Avatar
Darkstar_XIII
Has anyone installed a carbon fiber rear fender and/or aftermarket swing arm on their bagger?
I'd be curious to hear feedback, especially on what was used for a license plate bracket for the carbon fender and if you noticed better handling with the swing arm.
Old Mar 17, 2023 | 12:36 PM
  #1760
Kfuller1212
[QUOTE=Puglia10;21122047]Nature of the beast with floating rotors, my EBC do it as well. Doesnt bother me since they stop well.[/QUOTEt
Mine are semi floating due to how they mount on the special wheels. I commend you if yours sound like mine and it dont bother you. It's so loud. Going to try and rotate the rotor tonight. If they don't work maybe try some brake lube in the back of the pads. Buts it's not a squealing sound at all. It's so annoying.
