Another Wheel bearing thread
Old Nov 21, 2017 | 07:50 AM
dawg's Avatar
dawg
Originally Posted by penmaker
Where did you get your tools?
Google Pitposse wheel bearing puller/installer. That's the one that I run and it works well. Has three different size collars that come with it. Runs about $99
Old Nov 21, 2017 | 07:53 AM
dawg's Avatar
dawg
Old Nov 21, 2017 | 09:48 AM
MotoJockey's Avatar
MotoJockey
On eBay.......
I really like that it came with a case for everything.
https://www.ebay.com/itm/HARLEY-SEAL....c100005.m2219
Old Nov 21, 2017 | 10:19 AM
Imold's Avatar
Imold
Just an observation on Pit Posse style bearing puller/installers - they work very well, probably the best, but some have thrust bearings, some (Pit Posse itself) just have flat washers. The bearings are nice, but you get a similar reduction in effort if you just grease the washers and nuts that turn against each other. I also grease the tool's threaded portion for less friction. This makes a big difference when you're pulling a tight bearing, and Harley bearings should be very tight in the wheel bore.
Installing, you can freeze the bearing first, shrinking it slightly, and that can make it easier to squeeze in. I lubing the bearing sides and wheel bore when installalling. I use anti seize to reduce chances the bearings will get any corrosion binding it in the wheel, which I have run into on older bikes.
Old Nov 21, 2017 | 11:19 AM
penmaker's Avatar
penmaker
Thanks for the info on the tools. All I had seen was the JIMS and Heartland and they are well north of $99. I'll look into those. I've had the dealer check mine and they say they are good. I've still got ESP coverage so I was trying to get them replaced under that. I guess I need to pull my wheels and check them myself and replace them.
Old Nov 21, 2017 | 11:40 AM
L88's Avatar
L88
All very good tips.
It's not just straightforward, but with a little creativity and using the old bearings you can pull and replace the rear wheel pulley bearings with the Pit Posse.
Old Nov 21, 2017 | 01:08 PM
skratch's Avatar
skratch
if you're really interested in picking up the tools, there's a 'used' set on amazon for $60 with free prime shipping. if you have to have new, $75.72 with free shipping.
i'd jump on the used set myself, but don't really have the funds to do so right now.
Attached Thumbnails Another Wheel bearing thread-screen-shot-2017-11-21-at-1.06.18-pm.png
Old Nov 21, 2017 | 01:29 PM
memphisharley's Avatar
memphisharley
Originally Posted by L88
All very good tips.
do tell...
Old Nov 21, 2017 | 07:51 PM
sh4325's Avatar
sh4325
I recently read a piece in one the the motorcycle mags, they were talking about wheel bearing failures/replacements. They said to never spray a pressure washer/car wash wand on the sealed wheel bearings. The water will enter the bearings. And we all know what happen to a bearing when water gets into the grease. Had a boat for years. Backing the trailer in and out of the water always gave the problems with the bearings.
Old Nov 21, 2017 | 09:15 PM
memphisharley
hmm..im sure they get soaked while riding in rain so I don't see the difference.
