Neglected garaged FLTRI
Old Nov 25, 2017 | 08:19 PM
theboot801's Avatar
theboot801
Stage I
Default Neglected garaged FLTRI
My 2003 FLTRI has not been ridden almost two seasons. A month ago l noticed sludge in the pan that l put under the bike. I want to resurrect it for next season. Is there any hope? How should I proceed? Thanks for any input.
Old Nov 25, 2017 | 08:24 PM
SG-Jay's Avatar
SG-Jay
Have you started the bike in the last 2 years? What is the sludge? Just dirt that has attracted to a bit of oil in the pan? What does the oil on the dipstick look like? I'd change the oil and gas and try to crank it over.
Old Nov 26, 2017 | 08:00 AM
0lowrider1's Avatar
0lowrider1
I would check and change engine oil,primary and trans. I would even remove the spark plugs and put some oil in the cylinders and raise the bike and turn motor over by turn rear wheel .
Old Nov 26, 2017 | 08:53 AM
lionsm13's Avatar
lionsm13
Welcome to the forum on your very first post.
Old Nov 26, 2017 | 09:19 AM
Spartanden's Avatar
Spartanden
Welcome from Spartan Country Michigan!
Get a factory service manual and parts manual if you don't have one.
use search feature or be prepared for some smart a$$ responses from some members! we all have a hankering to help!!!
Old Nov 26, 2017 | 09:32 AM
Just Mike's Avatar
Just Mike
As has been said. Change all 3 oils, new spark plugs, drain gas and fill with new gas, charge up battery, change oil and air filter, air up tires Fire it up, go out and blow the dust off. I’d do a flush and fill of brake fluid too.
The sludge in the pan that is exposed to atmosphere is in no way indicative of what is going on inside your case. The oils dripping in pan are attracting and retaining all the dirt and dust floating around. This isn’t happening inside your engine.
Old Nov 26, 2017 | 10:01 AM
bigdumbnoitall00's Avatar
bigdumbnoitall00
with a 14 year old bike thats been siting its time to go over it. fuel lines tires bushings mounts cables hoses and electrical.
Old Nov 26, 2017 | 10:04 AM
judgedelta's Avatar
judgedelta
If your battery is several years old, hasn't been charged in a couple of years and has been exposed to real cold (as opposed to Mississippi cold) it may very well have gone bad. You might consider taking it out and having it tested before you trust it out on the road.
Old Nov 26, 2017 | 10:08 AM
lp's Avatar
lp
Drain any gas you had in it. Hopefully your EFI is not gummed up.
Old Nov 26, 2017 | 10:19 AM
hbsoldier3's Avatar
hbsoldier3
I would do as some have suggested above, the fluids, battery, oil filter, and gas. Then see if it will fire, if so, then I would change all the rubber fuel lines, cables,and brake fluid.
