Neglected garaged FLTRI
Old Nov 26, 2017 | 11:14 AM
cwsharp's Avatar
cwsharp
Originally Posted by bigdumbnoitall00
with a 14 year old bike thats been siting its time to go over it. fuel lines tires bushings mounts cables hoses and electrical.
Yep... everything that is 'rubber' deserves a very careful review.
Old Nov 26, 2017 | 12:08 PM
larsfum's Avatar
larsfum
I would drain the old gas out. Charge the battery & have it load tested. Then put a little fresh gas in and see if it will fire up first. If she starts shut her down immediately. Then do a three hole oil change, plus brake fluid, and fork oil. Check the date on the tires. If they are old, or suspect swap them out. Add some seafoam into the tank, and add more gas, and take her for a ride. Deal with any other issues as they pop up.
Old Nov 26, 2017 | 12:25 PM
groupw's Avatar
groupw
Originally Posted by Just Mike
The sludge in the pan that is exposed to atmosphere is in no way indicative of what is going on inside your case.
....... why is there enuff oil dripping from the machine to be able to be called 'sludge in the pan' ?
Old Nov 26, 2017 | 12:35 PM
heavymetalthunder's Avatar
heavymetalthunder
Originally Posted by hbsoldier3
I would do as some have suggested above, the fluids, battery, oil filter, and gas. Then see if it will fire, if so, then I would change all the rubber fuel lines, cables,and brake fluid.
I'd do all the above plus check the tires for flat spots and age. If over 5 years old I'd be changing them before riding to much.
Old Nov 26, 2017 | 12:37 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Welcome.
Old Nov 26, 2017 | 06:20 PM
smitty901's Avatar
smitty901
Welcome . You have already been given some good starting points..
Miles on the bike and more information about it would help get more detailed.
sweetpea123
Sep 23, 2013 07:10 PM
dandanny81
General Topics/Tech Tips
Aug 1, 2012 02:51 AM
shortleg
Feb 15, 2009 07:12 AM
bikecop40
Oct 30, 2006 01:03 PM
mndemohead
Oct 22, 2006 07:00 PM
