2008 electra glide questions before purchase
Old Dec 16, 2017 | 11:14 PM
  #31
stroker87's Avatar
stroker87
Originally Posted by svarnster
sounds like about 5-600 bucks and a couple of afternoons and u got her set. goodluck.
thanks
thats what im thinking, after Christmas im going to start buying the parts, fluids and probably some extra chrome then once the weather starts to brake get it all done for riding season
Old Dec 17, 2017 | 11:10 AM
  #32
dawg's Avatar
dawg
Originally Posted by stroker87
$180 to just hook up the rear speakers that are just unplugged since the tour pak is on a quick release mount
Since an FLHTC does not come with rear speakers like the ultra, the HK radio needs to be flashed in order to recognize the rear speakers. I assume that is where the $180 comes from and not simply plugging them in.
I have an 08 ultra since new (Aug 07) and it is a solid bike. I've added many extras and changed many things over the years but everything else has been routine maintenance. I've added a TWR Missing Link (kinda like the TruTrak), I changed out the too tall gearing with an EVO Ind. 49 tooth ring gear conversion, SE comp, Hayden tensioner, Redshift 575 cams, Zippers dual piston tensioners, etc. I've left the engine unmolested until the mileage warrants having to freshen it up. I've only had to replace the shift shaft seal and a rocker box gasket at 50k miles due to leaking. I just replaced the original 10year old battery this year. 08's are good solid bikes. Do all my own work, including tire changes. It never sees the dealer, excepting the recalls that were done years back.
Old Dec 17, 2017 | 11:13 AM
  #33
stroker87's Avatar
stroker87
it has an aftermarket radio installed so no programing is needed, they have been wired on a plug so the tour pak can be plug and play removed/installed
Old Dec 17, 2017 | 11:22 AM
  #34
dawg's Avatar
dawg
Don't know if it's your cup of tea, but polished engine covers are easier to have powdercoated than the chrome ones. To make it your own, you could have the covers coated to black things out while you're doing all your work. What I did was an even up swap with someone where I gave them my chrome covers for the FLHTC and I took their polished covers to have them powdercoated.
Old Dec 17, 2017 | 12:24 PM
  #35
rollonfreebird's Avatar
rollonfreebird
I have an 08 also, bought it from the original owner, 18k miles, mine is loud too going into first gear so was my heritage, had it for 2 yrs now, love it, good luck on your search
Zach Walsh
Apr 20, 2017 06:11 AM
Myke Malicious
Oct 18, 2015 10:52 PM
Mercyfulfate
Oct 23, 2012 06:45 AM
sportster-08
Sep 13, 2011 11:42 AM
zlaneb
Aug 17, 2006 01:37 AM
