5K service - did it myself
Old Jun 16, 2007 | 10:26 PM
RonH's Avatar
RonH
Default 5K service - did it myself
Just finished the 5K service on my bagger - it's a great feeling to do it yourself. The service manual was a perfect road map and the Fix My Hog DVD helped a lot too. And man it's sure nice to save all that cash for more important stuff!
Old Jun 16, 2007 | 11:29 PM
gibbyair's Avatar
gibbyair
Default RE: 5k service - did it myself
I'm coming up on my 5K for my 07 ultra. I have the service manual but haven't looked at it for the 5k. anything I need to know about, any special tools or anything tricky?
Old Jun 16, 2007 | 11:48 PM
voodoodrug's Avatar
voodoodrug
just did mine. felt like it was more of a good inspection and oil change. Only real service this bike needs is to be taken out an ran,dont over look that ............[sm=biker.gif]
oh ya check the stuff the dealeroverlooked at the 1k like lube the stering neck[:@]
Old Jun 17, 2007 | 12:13 AM
RonH's Avatar
RonH
ORIGINAL: gibbyair
Nothing tricky - Like voodoodrug said it really is more of a once over with an oil change. The belt tension gauge is helpful for that adjustment, but everything is pretty much straight out of the service manual. You need torx stuff and inch pound and foot pound torque wrenches. Just follow the book and you'll be fine. If you log onto the HD site and enter your VIN number and mileage it will bring up the 5K service list. I printed that out and just checked each thing off as I did it, dated it and put that in a file with my oil receipt.
Old Jun 17, 2007 | 11:24 AM
swipter's Avatar
swipter
[/quote]
[/quote]
So I went on the HD site to do that but can not find the enter mileage and print the sheet thing you talk about.
Old Jun 17, 2007 | 11:43 AM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: gibbyair
Like said before get a belt tension gauge,proper sockets(Torx set w/#27) and regular sockets.Inch andpound torque wrenches.
You can also buy a primary chain gauge but there are methods to check the play.
Also there are special sockets availible for the clutch hub adjustment but again there are other ways(tools to use)for the adjustment.
Dont forget the beer!
Old Jun 17, 2007 | 01:57 PM
RonH's Avatar
RonH
Here's the link to the HD site for service info:
https://www.harley-davidson.com/EX/MNT/SCHK/en/servicecheckup.asp?locale=en_US&bmLocale=en_US&Web LogicSession=G1nyUcSA5Yy52k1diAh6xRJ78VlIUhPFol6ki VW9FCN2hAgwMt88!373756752!181237811!7005!8005&nick name=Ron%2C+Ron
Old Jun 17, 2007 | 02:14 PM
mazeppa's Avatar
mazeppa
Default RE: 5K service - did it myself
ORIGINAL: RonH
Now you know ALLof it wasdone, and done CORRECTLY.
Old Jun 18, 2007 | 06:27 PM
07FLHRCMarinePatriot's Avatar
ORIGINAL: gibbyair
Just a small note: the manual says not to put in more than 3.5 quarts of oil after a full drain and filter change. I could only put in 2.5 before the dipstick said full, then I ran it as recommended so I could get a hot reading. That told me to add about 1/2 quart (which prob about equals what the new filter captured), then I let it set overnight. Next day, cold reading had me put in about 1/4 quart. Therefore, I ended up only putting 3 1/4 quarts back in, instead of 4. And that's after having let it drain till nothing was coming out! But, always good to not over-fill!
Old Jun 19, 2007 | 06:00 AM
PapaTravis's Avatar
PapaTravis
I will be doing mine this week, once I can find the fluids. Amsoil 20w-50 for the engine and primary. And redline shockproof for the transmission, Right? Does this sound like a good combination? Also, having a hard time finding the redline. What else is good to use on my '05 rk custom? Or, where can I get the redline?
