I found a post the other day on seting the tm to map 393 and changing the a/f to 13.19 on several of the rpm pages. I tried to find it again after I did it, but no luck. Any way if the author is reading this thanks it worked great. No popping unless I am slowing down with a little throttle still on. Nothing I am worried about. The tm is super
Your welcome. Glad it worked for you. You can tweak the map some more for the exact rpm you are still getting popping in if you want to.
It worked great like I said the only popping I get is slowing down with some throttle and it is not a major pop just a little gurgle. Thanks again. sugarbear
Yeah they do gurgle a lot. It'sa completely different sound than I getfromthe Vance and Hines Big Shots on my Deuce.
