Heated grips 2016 ultra
Old Jan 1, 2018 | 05:46 PM
fast johnny's Avatar
fast johnny
1st Gear
Default Heated grips 2016 ultra
Changed handlebars, pulled heated grip control side (left) through bars. Pulled throttle side (right) through bars.
Checked for power from bike,good. Plugged control side to power, checked power from control side to throttle side, good.
Plugged control side power to throttle side. No heat.
Any suggestions??
Thanks
Old Jan 1, 2018 | 07:02 PM
Charger500's Avatar
Charger500
On the throttle side, the heated grip has a short wire that plugs into the end of the twist grip sensor. I would check to make sure that connection is good. There is a recent good video on YouTube of heated grips installed on a newer street glide, you may want to check it out.
Old Jan 1, 2018 | 07:06 PM
davidwruth's Avatar
davidwruth
Stupid question. Did u check the ground wire
Old Jan 1, 2018 | 08:34 PM
fast johnny
1st Gear
Thanks Charger, but like I mentioned, I've got power coming out of control side to throttle side, with good condition, but no heat.
There is only one way to hook up with male and female ends, so I'm lost as you can tell.
Old Jan 1, 2018 | 09:17 PM
ROCKOUT Rocker Products
Sponsor
Be sure you have the connectors plugged into the right places. The factory instructions are more or less useless here.
Here's a post I made when I did my '15 limited, showing the correct locations...
https://www.hdforums.com/forum/touri...l#post14752098
Good luck!
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Highwayman-AL
Dec 8, 2015 09:35 PM
YtseJam
Electrical/Lighting/Alarm
Nov 2, 2014 09:14 PM
Blt93932@aol.com
Feb 3, 2013 07:30 AM
happycampinman
Nov 10, 2010 03:21 PM
gblass1
Sep 20, 2008 08:07 AM
