Power outlet location
Old Jan 15, 2018 | 09:47 AM
F150HD's Avatar
F150HD
Originally Posted by woggy101
I am considering putting a power outlet on my 2012 Ultra Classic. Any suggestions as to the best spot, other than on the handlebars? Thinking about part # 91843-97 and putting it thru the back end of the right side heat shield, or would it get too hot for the unit and/or wires?
Kinda unclear as to why you wouldn't just put it IN the tourpak?
I have a 2012 Ultra (not a Limited) and put the HD one IN the tour pak. Nice to plug in the phone (or tablet) and it charges while riding. Also at a gas stop no one can see it (unless they open the TP) so no theft. Protected from the elements in the tourpak (think- riding in rain)- I wouldn't want a phone in my pocket charging while riding (unless I had no choice due to the style of bike I had)
I wouldn't want one in the left side saddlebag as when the bike is parked it leans left and a PITA to get in and out of that bag on occasion. That's also my 'tool' saddlebag on trips so I don't access it unless necessary.
https://www.harley-davidson.com/stor...ary-power-port
Was only $30 when I bought it go figure. If you remove the tourpak liner this is plug and play into the tourpak left side rear taillight receptacle- there's an empty plug there for it.
Edit: not sure if you do major touring, but, putting your phone into Airplane mode is a wise idea at the start of each day, then dim the brightness. It then functions as a camera but battery won't drain quickly. (Guessing many know that already! )
Old Jan 15, 2018 | 09:52 AM
Scat_Pack's Avatar
Scat_Pack
I should have added that the usb cable for my phone is the "flat" style. I can run it into my saddle bag if I'm in inclimate weather. It will still latch and seal, keeping my stuff dry. But, it's nice to have the option to slide it into my pocket and the wife can use her phone while it's charging and we are cruising down the road.
Old Jan 15, 2018 | 10:46 AM
cprhed's Avatar
cprhed
In that case I would recommend putting an accessible dual USB outlet perhaps under the side cover. You could run an extra charging cable up to the tourpak along the factory harness and leave it there all the time. That way you have that in the tourpak.
Wife can plug into the second port and the cable would come up right between the two of you.
Old Jan 15, 2018 | 12:15 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
One more thing, I advise the usb should be at least 2 amp so it can charge smart phones that might be in use while charging. Been down that road before, 1 amp will not get it done.
My passenger plugs into a deltran 2 amp converter that plugs into the battery tender pigtail, used when needed. Text away, Sweetie...
https://www.amazon.com/Battery-Tender-081-0158-Disconnect-Smartphone/dp/B00DJ5KEF4/ref=sr_1_fkmr1_1?ie=UTF8&qid=1516039988&sr=8-1-fkmr1&keywords=deltran+2amp+usb+charger https://www.amazon.com/Battery-Tender-081-0158-Disconnect-Smartphone/dp/B00DJ5KEF4/ref=sr_1_fkmr1_1?ie=UTF8&qid=1516039988&sr=8-1-fkmr1&keywords=deltran+2amp+usb+charger
woodmnctry
13
Nov 2, 2016 06:09 PM
MikeBel
Apr 8, 2015 01:15 PM
labman
General Topics/Tech Tips
Aug 7, 2014 06:30 PM
turnerbend
Mar 9, 2013 11:50 PM
Navy UC Rider
Mar 13, 2011 03:47 PM
