Instruments Inop
Old Jan 26, 2018 | 07:11 AM
PROVIDER7's Avatar
PROVIDER7
Default Instruments Inop
Could use some backup. I have a 08 Streetglide that all of a sudden the instruments quit working on (tach,speedo, fuel,oil press, volt gauages) also no neutral light. Bike starts a runs fine, brake,turn sigs,headlight work fine. Can't check for codes as theirs no power to the odometer..
Troubleshooting I've done so is to check the fuse which was good.
What else should I look at?
Thanks in Advance for any advice.
P7
Old Jan 26, 2018 | 07:25 AM
davidwruth's Avatar
davidwruth
Have you done any mods to the bike? Recently or not.
Old Jan 26, 2018 | 07:39 AM
86glider's Avatar
86glider
If you have the service manual ,follow wiring diagram ,could be a bad breaker?
Old Jan 26, 2018 | 08:40 AM
14GuineaPig's Avatar
14GuineaPig
It looks like the "instruments" fuse brings power to the speedo tach, & gauges.
Old Jan 26, 2018 | 08:46 AM
hbsoldier3's Avatar
hbsoldier3
Did you check the accessory fuse, had similar problem on my RK?
Old Jan 26, 2018 | 08:52 AM
grbrown's Avatar
grbrown
Red face
I would replace the fuse, even if it looks OK. If it still doesn't work, then get your multimeter and FSM out!
Old Jan 27, 2018 | 08:28 AM
PROVIDER7's Avatar
PROVIDER7
Roger, will replace the fuse with a new one! And check the accessory fuse. No new mods, rode to work all week Monday- Wednesday no issues, Thursday no instruments happen overnight!
Any other recommendations/ input will be much Appreciated.
P7
Boots3139
Aug 14, 2018 09:19 PM
jim70
Oct 4, 2016 07:16 AM
FLTpilot
Mar 18, 2014 06:58 AM
Matt Lobo Lowe
Jun 5, 2012 08:23 PM
04RoadKing
Jul 8, 2006 04:16 PM
