Needed Maintenance + Upgrades advice for 09 FLHTCU
#1 failing Compensator
#2 leaking Clutch Cable
#3 front Brake pads are dead
#4 20k mile service
I know i want to take my bars to 12in-14in, which since I need a new clutch cable anyway I might as well go ahead an go for it.
With the Compensator dying on me I am trying to decide between the Screaming eagle replacement or the Baker compensator possibly with the attitude adjuster as well.
With all that going on I am thinking Cams for a bit more bottom end for getting up some mountain roads this fall.
Now all ya'll spend my money. I wanna keep it below 4k closer to 3k.
Thanks
If your going with longer bars and already need a clutch cable, check out the Burley cable packages. They give you everything needed for the length of bars your installing in plus sizes increments (+4, +6 and so on), very good product. They include clutch, throttle, brake and electrical.
If you do change your cams, selecting a cam size will be your next challenge. I would consider changing your inner cam bearings as well. I'd upgrade to the continuous roller type, not caged. May as well change the inner cam tensioners while your in there; there are two tensioners, one on the outside of the cam support plate between the crank and the cam and one on the inside which provides tension to the chain going around both cams.
Brake pads are easy but be sure to do a thorough caliper service and cleaning at the same time. Ensuring those pistons are clean and go in and out evenly are key to good braking performance and long brake pad life. You should consider doing a brake flush at the same time.
I could go on but the most important part is doing a thorough inspection of your entire bike. Good luck!
bars, magnum lines for brake, clutch cable I would go barnett
I would also decide since you have exhaust at least loose to change out clutch cable if you wanted something different.
cams, just do it but do it correctly, if your 09 is a 96, woods 222s or Andrews 48, if you think you are going 103 or 107. Woods 555 or Andrews 57, or any of the other brand name cams. Also replace bearings o rings cam shoes even plate and pump if necessary, last change lifters, go S&S.
brakes, I would use the stock pads, change out to floating rotors and pickup a brake flush regardless of ABS OR not.
if you have front wheel off, if your close to needing a tire, I would get one and change bearings.
clean everything.
since you have front wheel off and fairing apart for bars, may as well go ahead and service front forks, I'd go progressive mono tubes and either chrome or black out the front end
To keep your budget in check, I would look at a cheap set of SE255 cams... I had them in my 2009 flht ,, just the thing for what your after , (mountain riding etc) ....
Pity you or your mates aren't handy on the tools ,, as compensator / cam upgrade is really not that daunting , (especially with u tube etc)... A good project that would be satisfying , learn about your bike ,,, and save a lot of bucks .....
I'm happy with my Twin Power floating rotors + Speed Bleeders for fluid flushes. Factory rotors aren't true floating rotors & I had one warped enough to cause light brake drag with less than 15k mi on the bike. These Twin Powers are a great value IMO. Important to flush that DOT4 fluid every 2 yrs & stainless Speed Bleeders make it quick & painless for me.
Stock suspension really sucked in 09. Pulled my fork tubes & sent to Race Tech for gold valve emulators & new springs. Huge improvement - no more brake dive & eats up the road. Rear air shocks felt even worse then so ditched them for Bitubo (Italian) coil over shocks. Another great value IMO.
Barnett stainless braided clutch cable has been up to the task with my heavy clutch spring with no leaking. Can't say the same for Motion Pro - leaked a couple hundred miles after install. Barnett has a soft metal spring that can slide up & down the cable that you position as an isolator where the cable wants to rub the cases. Seems counter intuitive but it's soft enough that it plants itself against the case & doesn't move. Other brands lacking this will eat themselves alive with their stainless braid rubbing into your case at the same time. All the vibration causes the leak & damage.
Your cush drive will probably be shot with 20k on the clock. I went to Alloy Art's green super cush at my last rear tire change. Should hold up a lot longer than the stock rubber gizmo.
Just my experiences as I've gone through mine over the years similar to your line of thinking - do what makes sense when you've got it apart anyway.
#4 20k mile service
Thanks
New cam job will run $1500
$4 K will get eaten up pretty fast.
