Front End Question
Old Feb 28, 2018 | 11:25 AM
SnoRider's Avatar
SnoRider
Default Front End Question
I have a 2011 road king. Can I swap triple trees from a 14+ model without any massive modification?
Old Feb 28, 2018 | 05:06 PM
2black1s's Avatar
2black1s
As far as I know the diameter of the tubes changed in 2014. Therefore the answer would be no.
Old Feb 28, 2018 | 05:16 PM
hattitude's Avatar
hattitude
The answer to your question is "No"....
But.....
Howard, at Motorcycle Metal, has some custom triple trees that will allow you to put the 49mm forks from a '14-16 bagger onto your '09--'13 bagger...
Old Feb 28, 2018 | 06:59 PM
SnoRider's Avatar
SnoRider
But.....
This is what I wanted to know. Wanted to go 49mm. Thanks!
Old Feb 28, 2018 | 07:12 PM
todd-67's Avatar
todd-67
The larger tubes are not that much of a difference if the internals are set up right. I ride both setups.
Old Mar 1, 2018 | 12:50 AM
SnoRider's Avatar
SnoRider
Well I want to swap my monotubes out for something better like FKC 101. If I’m not imagining things...aren’t there more options or better options for 49mm bs the. 41mm? I can almost guarantee I can’t afford to do extra front end work like triple trees and inverted forks or whatever but thought...hmm maybe I could find a 2014 front end and just swap the whole thing..
Old Mar 1, 2018 | 04:13 AM
todd-67's Avatar
todd-67
I think you might be chasing unicorns. The short travel suspension both front and rear are limited on what you can expect to get out of them. The monotubes are an improvement over stock. I have them and they could be better but what are you trying to gain?
Old Mar 1, 2018 | 05:20 AM
Ex-Leftcoaster's Avatar
Ex-Leftcoaster
If you're wanting to switch out your current monotubes to, say Ohlins, they make them for both the pre-Rushmore bikes and Rushmore bikes. Other manufacturers do as well. No need to change forks,
Old Mar 1, 2018 | 07:38 AM
hellonewman's Avatar
hellonewman
The difference with the 14 up is also the upper tree clamps the tube so its stiffer. How much I dont know but its gotta be better than a 13 down. My 2011 with the front wheel in a chock is laughable how much flex there is when I move the bars and its not the bars moving in relation to the tree.
Old Mar 1, 2018 | 07:55 AM
grbrown's Avatar
grbrown
Cool
Yes there are more and better options for the 49mm forks. The Ohlins 25mm FKC101 cartridge is for 41mm forks, their FKC102 for 49mm. Neither of those are adjustable, but come with superior damping than most set-ups out there. The 49mm forks will also take the fully adjustable Ohlins 30mm cartridges, which probably set the gold standard. Howard is the acknowledged expert on all such things!
As for 41mm forks, CCE makes a kit with clamping billet top tree and extended fork tubes, which I have on my older Glide (along with FKC101 cartridges). I also have Ohlins #3-3 rear shocks, so have a mid-price suspension set-up, which is an alternative solution, a good deal cheaper than a swap to 49mm. However if you want the 30mm top-shelf solution then going to 49mm forks is definitely the way to go, along with #6 shocks.
