Saddlebag locks
Old Mar 1, 2018 | 07:04 AM
Soulpatch1's Avatar
Soulpatch1
1st Gear
Default Saddlebag locks
2013 FLHTCU... Bought some 2014 extended bags and was wondering if it's possible to pull the locks from my old bags and install on the new ones? So that everything (bags/tourpack) is still keyed the same? Not a big deal, just a convenience more than anything.
Old Mar 1, 2018 | 07:31 AM
nobodyknowsme's Avatar
nobodyknowsme
Of course you can as all the hardware comes apart. Have had to replace springs, changed out covers, etc...
Old Mar 1, 2018 | 08:05 AM
grbrown's Avatar
grbrown
I've done exactly that on my earlier bike, no problem. These things don't change very fast in the Harley world!
Old Mar 1, 2018 | 08:17 AM
Soulpatch1's Avatar
Soulpatch1
1st Gear
Excellent, just wasn't sure if there was any difference between 2013 to 2014. The latching system is completely different, but hard to tell until it's all in pieces. Didn't want to go through the effort if it wasn't worth it. Appreciate the feedback, thanks guys.
Old Mar 1, 2018 | 10:38 AM
Soulpatch1's Avatar
Soulpatch1
1st Gear
Nope, didn't work. Took them apart and removed the locks. The 2014 has a stop tab at the bottom of the mechanism (6 o'clock), while the 2013 is about 8 o'clock. It's too far to be of use, since it's pushing/pulling a cable, vs. the old is just a tab that swings into the slot. No biggie, just means I have to carry two keys instead of just one. Like I said before, just a convenience thing more than anything else. But you never know until you try and maybe this will help anybody else who's thinking of modifying enough to run the 2014 bags. Off to the next endeavor, finding bag lids to move the speakers!
Old Mar 1, 2018 | 10:55 AM
0ldhippie's Avatar
0ldhippie
Bags and hardware changed in ‘14...
Old Mar 1, 2018 | 11:26 AM
skratch's Avatar
skratch
if it's worth $80 to you, you could order the new locks, specify your existing key code, and then switch them out. (item 26)
if you order them from your discounter, could even get them for less.
Attached Thumbnails Saddlebag locks-screen-shot-2018-03-01-at-11.23.19-am.png   Saddlebag locks-screen-shot-2018-03-01-at-11.24.01-am.png
Old Mar 2, 2018 | 06:36 PM
eglideic's Avatar
eglideic
I just did this to my 2013 Ultra. Put 2014 and later bags on it.
I bought new locks that used my 2013 key number. $80.
I did have to slightly adjust the front saddlebag mount, BUT the part I didn't like, was I had to remove my saddlebag guard rails because the new bags were a bit wider and wouldn't fit with the guard rails.
streetglidekid09
Aug 21, 2016 11:11 AM
DaSham58
Jun 15, 2014 07:40 PM
Mississippi Birdman
Sep 25, 2011 07:59 AM
abate1
Shovelhead
Apr 25, 2010 03:44 PM
mrbuck
Mar 13, 2008 09:10 AM
