GPS Headlight Acc Lead Installation Issue
A few Questions:
How old is it?
When was the last time it was updated?
Is the internal battery charged?
How is it hooked up to the bikes power?
Mine is connected to the bike through the Zumo cradle (using the Fairing Mount.)
It is connected to the orange/white from the headlight circuit [29B] (which is unused on domestic bikes.)
With the Zumo mounted in the cradle, everything off, when I start the bike the Zumo comes on.
Once the GPS has finished booting, if I shut the bike down I get a window that pops up on the GPS screen warning that it will shut off in 30 seconds, then counts down until it shuts off. (It does give you the option to leave it on internal battery power.)
If I do nothing the Zumo will shut down and remain off.
When the bike is restarted the route I had loaded in it is still loaded (as long as there is enough internal battery power.)
Maybe you want to apply updates and/or call Garmin?
Although they both use an orange/white wire and connect to the same circuit.
The wire in question is for the HDI Position Lamp required in some countries, but not in the U.S.
This is where HD tells you to connect the Zumo.
Many CVO Ultras that came with the Zumo have an orange/white wire directly run to the fuse block instead.
