Welcome from Hampton Roads Virginia. Ask the same question over in the other form area. This area is for new member welcome. Upper left. Forums..Harley Davidson Tech and Mechanical..Frame and Suspension
Have you taken the outer fairing off yet? It is common for the fairing support brackets to break.
I have never heard that or experienced it in 3 Road Glides. I have known a few people and read of countless others having the brackets break on a batwing but OP has a Sharknose.
OP, grab the fairing bottom from the front and see if it is loose there. May just be the brackets loose on the engine guard but probably not. Most likely where they connect to the frame. If you have not taken it apart or do not know how, plenty of Youtube videos.
I have a 2008 Roadglide. The fairing rattles at idle,how do I fixit?
Hi from the UK and welcome to HDF. As others have suggested you need to identify what is causing the rattle. It is possible a bracket has broken. You can see a breakdown of your fairing, in fact your whole bike, right here. If you need to dismantle your fairing I suggest you buy a FSM first.
yep, I read the original post too fast and didn't even notice he was talking about a road glide...
