Custom Dynamics Strobe Brake Light Module
Old Mar 14, 2018 | 07:51 PM
madmat's Avatar
madmat
I have had the magic strobe on both my RG's. It is an obnoxious necessity in a save your life kinda way
Old Mar 14, 2018 | 08:00 PM
Spartanden's Avatar
Spartanden
Was not happy with the light output of the rear on my Street Glide, but like the looks. Had CD on my Sporty, so that was the first thing I did. Plus I added Plasma Rod to the edge of the trim panel between the bags and fender. So I doubled up my run/turn/brake lights. Then last fall due to broken wire, I replace the tri-bar lamp with one of CD led lights. What a difference!!! Just love the CD led's and their modules!!
Old Mar 15, 2018 | 05:35 AM
DamifIknow's Avatar
DamifIknow
Originally Posted by Veekness
I just installed the CD LED running lights kit and the Tri Bar kit which included this module. I must agree with you.
The epoxy around the switches is melted, but the unit works fine. Nonetheless, I'll give them a call to see if it' gonna be an issue.
The one for my 2012 was same way . I just thought it might be a rebuilt or repaired unit.
Old Mar 15, 2018 | 06:25 AM
overthehill?'s Avatar
overthehill?
The HD led bar for the Air Wing luggage rack is woefully weak, so I purchased a similar product from CD and it is way better...especially that when you engage any brake it blinks 5 times before staying on.
Old Mar 15, 2018 | 08:38 AM
Daytona Fat Boy's Avatar
Daytona Fat Boy
I switched over to Custom Dynamics' set up after having a Bright *** tail light on my last few bikes. Rear running lights and center tail light all flash when the brakes are applied, not just the center light. Better warranty too. Also went for the front Ringz running/turn signal set up. With 5 bright white lights on the front of the bike, I'm betting I'm going to be seen, so I'm not looking for a modulator. If they run me over now, they wanted to.
Pretty sure modulators are now legal in all states. Didn't know they worked with LEDs though.
Old Mar 15, 2018 | 09:44 AM
lionsm13's Avatar
lionsm13
Gotta suggestion for the modulator? . (Apologies to the OP for the sidetrack)
Yep.
Kisan path blazer. https://kisantech.com
They are in CO. Springs CO
I run one as well as the BAL.
They also have tail light modules.
Wouldn't run w/out either of them.
As you say gotta have all the edge you can get.
Old Mar 15, 2018 | 09:52 AM
Veekness's Avatar
Veekness
Originally Posted by lionsm13
Yep.
Thank ya, sir...I will look into this. I've never run a headlight modulator, but I tellya what, I've never seen such crappy drivers on the road these days... any advantage is welcome!
Old Mar 15, 2018 | 10:26 AM
DRBUICK's Avatar
DRBUICK
did the strobe as well love it
Old Mar 15, 2018 | 10:56 AM
Oko's Avatar
Oko
Originally Posted by Johnnyh14
I think the flashing headlight may be illegal in some areas .......
FYI- daytime headlight modulators have been legal in ALL states for approx. 30-yrs. It’s a Federal thing. Always kept with me the legal paperwork Kissan packages with their product just in case I ran into an LEO that didn’t know. I’ve never had to show it.
The added benefit is that clueless cage drivers often pull over to let you pass. Often they offer up a one finger salute.
Bikevet
Aug 5, 2018 08:41 PM
CaptainAwesome
Jun 2, 2018 10:26 PM
nobodyknowsme
Jan 28, 2018 04:38 PM
jtsmitty
Electrical/Lighting/Alarm
May 1, 2017 04:11 PM
buellrider76
Mar 29, 2014 11:46 AM
