ABS Definitive Answer
Old Mar 21, 2018 | 02:39 PM
Rickr01's Avatar
Rickr01
Default ABS Definitive Answer
Hey folks...Does anyone have a definitive answer as to whether the ABS hydraulic unit on a 2010 FLHX does or does not self test and cycle itself when the bike is first started or if the brakes are not applied in a certain period of time from start up?
Thanks
Old Mar 21, 2018 | 03:00 PM
rigidthumper's Avatar
rigidthumper
ABS self test - simply checks for opens/shorts, and lamp will flash until a few MPH is achieved & sensors report proper even front & rear rotation. They do not activate/cycle unless skid conditions are met, and lockup is imminent.
Old Mar 21, 2018 | 03:07 PM
Rickr01's Avatar
Rickr01
Thanks. That's what I needed to know. Appreciated.
Old Mar 21, 2018 | 03:27 PM
kojak's Avatar
kojak
Your abs light should come on when you start your bike and go off when you hit about 3 mph. Means your system is working fine including your sensor.
Old Mar 21, 2018 | 03:44 PM
Peter Quinn's Avatar
Peter Quinn
Switch point is at 8kmh/5mph.Abs will not engage at speeds below this at any time!
junglejoe
2014-2024 Touring Models
55
Dec 21, 2015 06:47 PM
99%r
Feb 22, 2013 07:23 AM
qtrracer
Jan 31, 2012 09:48 PM
yorgo
Wheels/Tires
Jun 6, 2011 12:32 PM
WildHair
Jun 4, 2008 11:25 PM
