Primary oil
Old Jun 22, 2007 | 01:48 AM
gdkenoyer's Avatar
gdkenoyer
Default RE: Primary oil
Other.
Rotella T 15W-40 in the Primary (I agree with the comment re: primary doesn't need Syn)
M1 V-Twin in engine
M1 75W-90 in tranny
Old Jun 22, 2007 | 01:59 AM
Ben U
Guest
Posts: n/a
ORIGINAL: dstockton
Mobil 1 VTwin in the engine
Mobil 1 75w90 gear oil in the trans
HD Formula Plus in the primary although in a pinch I'd probably use any dino 10W40 or 20W50 oil. The primary don't need no expensive synthetic. It's just keeping the primary chain and clutch plates lubricated and cool.
Bingo
Old Jun 22, 2007 | 04:22 AM
Edmo's Avatar
Edmo
HD Formula +
Old Jun 22, 2007 | 07:59 AM
Longtimegone's Avatar
Longtimegone
Redline MTL
Old Jun 22, 2007 | 08:14 AM
StreetGlide2006's Avatar
StreetGlide2006
Red Line MTL in primary, Red Line Heavy Shock Proof in trans. and will do Red line in motor next change.
I tried Red Line in trans first and it made a big diffenence in trans noise and smoothness. Decided to try MTL in primary 2 weeks ago. Made things much quieter. Shifting noise is almost none. Since both Red line products have made me happy I will go with it in the motor next oil change.
Ride Safe,
Mike
Old Jun 22, 2007 | 08:34 AM
Mac57's Avatar
Mac57
H-D Formula + in the primary.
Old Jun 22, 2007 | 01:01 PM
Isolated01's Avatar
Isolated01
3rd Gear
Redline in all 3 holes.
Old Jun 22, 2007 | 01:23 PM
SG Mike's Avatar
SG Mike
Amsoil in all three
Old Jun 22, 2007 | 01:30 PM
Unclenuts's Avatar
Unclenuts
I use Amsoil 20w50 in all 3.
Old Jun 22, 2007 | 02:11 PM
EVOrider's Avatar
EVOrider
I have used 5w30 once in the primary....roadside repair. It worked fine, but there was a little slippage. I believe it was due to energy conservation. I recommend at a minimum 10w40 though.
I mainly use ANY diesel 15w40 in the primary. It is inexpensive and can be found almost anywhere. However, sometimes I end up using any 20w50 laying around the shop.
For the past 20+ years.....the primary gets 15w40 diesel oil
transmission gets 80w90 GL5
engine gets 20w50 for warm months and 15w40 for cold months
