Tire Losing Air
Old Apr 8, 2018 | 01:19 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Just ordered two Metzeler ME888 Marathon Ultra Tires from Dennis Kirk.
$377 shipped and no tax seems like a good price compared to the HD Dunlap's and from past experience with my VRod, the Metzeler's handle better.
Old Apr 8, 2018 | 02:58 PM
Ragtop's Avatar
Ragtop
Bend the value stem around while spraying soapy water.
I've had a lot of stems crack on me, but they looked fine until you bend them.
Old Apr 8, 2018 | 03:47 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Mine are the aluminum ( I think ), angled ones....No bending there.....
Tires were made in the 12th week of 2012, so I guess I'm due, even though thread & sidewalls look like new.....
My fault for not riding much in the last three years....
Old Apr 8, 2018 | 04:09 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
With bike up on the jack, tire aired up -
Put a container of water under the suspect wheel and ease the jack down until the tire is under water just over the rim. Slowly rotate the wheel. The leak will appear.
The spray bottle method works best with soapy water, a little dawn or joy in the water will usually make it appear very easily.
Sometimes my mountain bike tires will get a slow leak, and the submerge test on an inflated tire is the only way I can find it.
Trust me, if you have a leak, this will expose it. "Mark it".
Old Apr 8, 2018 | 06:07 PM
EdwardK's Avatar
EdwardK
Have you ridden it lately? The tire has to be spinning for the sealant to coat the inside of the tire to find the leak and plug it.
Still....I would also suggest new tires.
Old Apr 8, 2018 | 08:47 PM
cowboydoc's Avatar
cowboydoc
It might not be the tire. I had a similar issue except tires were less than 6 months old. My front tire would lose air - about 5 lbs overnight at first but then within a week it would go flat overnight. I could not find a nail or leak anywhere and eventually took it in to the dealer. It took them a while to find the leak, but it ended up being a small defect in the wheel, the tire was fine.
But, as mentioned above, a 5 year old tire is due for replacement.
Old Apr 9, 2018 | 05:26 AM
JackStaff's Avatar
JackStaff
Seen that fairly often on 4 wheel vehicles - the bead/rim mating was the culprit.
Old Apr 9, 2018 | 06:32 AM
harleyrider4300's Avatar
harleyrider4300
Default Opposite problem
I agree. Replace the tire
My wife’s bike had the opposite problem. Pre ride inspection found large nail protruding from side. Air pressure was right where it should be. Dealership that replaced tire was amazed
Old Apr 9, 2018 | 07:48 AM
Veekness's Avatar
Veekness
Your wife is right.
Old Apr 9, 2018 | 08:00 AM
HDV-GLIDE's Avatar
HDV-GLIDE
New tires and Ride-On sealant on the way.......
I'm hoping by spending the money makes me more motivated to ride more.....
Thanks for all the suggestions....
