oils
Old Apr 10, 2018 | 04:42 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
OP just got the internet.
Caught you all, hook line and sinker.
Old Apr 10, 2018 | 05:59 AM
bklynbob's Avatar
bklynbob
Generall,only one oil for a particular hole...
Old Apr 10, 2018 | 07:25 AM
PDB17UltraRG's Avatar
PDB17UltraRG
Same all three holes, these day all our oils are made of good products offering great protection just make sure its motorcycle oil. Not one is better then another just get the right spec for your bike.
Old Apr 10, 2018 | 10:09 AM
torchmaster's Avatar
torchmaster
Old Apr 10, 2018 | 10:28 AM
bigal51's Avatar
bigal51
I guess I'm the exception. I use Amsoil 20w50 in all three holes. No problem.
Old Apr 10, 2018 | 10:50 AM
woodthumb2's Avatar
woodthumb2
except for me.... i also use the same.. 20w 50w valvoline dino 4 stroke all 3... sometimes i will switch off to mobil but always dino... change engine every 2 to 3 thousand... others every 5..
Old Apr 10, 2018 | 11:10 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
All three holes Mobil 1 20w50 V-Twin Synthetic Oil, changed every 5K.
Old Apr 10, 2018 | 11:17 AM
hardheaded's Avatar
hardheaded
KY in all three holes !
Old Apr 10, 2018 | 11:26 AM
OldPhat's Avatar
OldPhat
Harley saz you can run Syn3 in all 3 holes, if your smart you won't.
The last time around I used Royal Purple max cycle 20/50 in the engine,
and Harley Formula Plus in the Primary and the Transmission.
The next time I will put a high quality Synthetic in the primary & transmission,
something like Bel Ray or Redline designed specifically for each hole.
John
Old Apr 10, 2018 | 11:33 AM
st john's Avatar
st john
Saw an interesting post about Primary oil and its relation to the famous shift clunk.
I am running M1 4T in the primary and the clunk although never went away did become less. OK, I change fluid again but only had M1 v-twin 20W-50 so I put that in. First I thought that it was my imagination but the Clunk did increase. The post talked about how 20W-50 can cause just a little more drag on the clutch plates than the 10W40, It was not harming the clutch but did bring back the clunk. Could be why Harley switched out from using SYN 20W-50 from their primary. too many complaints about the clunk returning. I will be going back to 10W-40, anyone else notice any changes in clunk vs. oil weight? and yes W stands for winter I am referring to 40 vs. 50 50.
