Running Hot
Old Apr 17, 2018 | 05:21 PM
Locadd's Avatar
Locadd
6th Gear
Default Running Hot
17 APR 2018 08:58 AM
I went to go for a ride with my son, we left Home and rode up to the next town (55 KM) when I pulled up at a traffic light I noticed that the bike was abnormally hot and had no oil pressure showing on the gauge.
We pulled into the closest servo and shut her down, I checked the oil and there was none showing on the dip stick, I put in 1 liter of oil and started the bike the only oil pressure I had was when I had some revs on the engine.
I rode it back home and the oil pressure was OK while riding, but by the time I got back home The bike was again abnormally hot again and had lost all power.
I left it overnight and then restarted it, it had good oil pressure and showed no signs of getting hot – never had time to go for a road test.
Any thoughts on what may have happened?
2010 Ultra Classic – stage 2 Big Bore Kit
Cheers
Locadd
Old May 11, 2018 | 08:29 PM
Shawrco's Avatar
Shawrco
Default Running Hot
Happens all the time... engine gets hot and oil pressure drops very low at idle. Comes back up once rpm increases. Low oil quantity is another issue... may need to check before riding for a while to see what's going on with that. Ride safe.
Old May 11, 2018 | 10:19 PM
Veekness's Avatar
Veekness
Agreed...a healthy Big Twin only 8 or so PSI at idle. Then it comes up to 30 to 32 more or less.
Old May 12, 2018 | 02:04 AM
Joe from So Cal's Avatar
Joe from So Cal
I'd ask how did this happen? After a 55 km ride it was probably not showing on the stick before the ride.
Old Jun 12, 2018 | 08:51 AM
Locadd's Avatar
Locadd
6th Gear
Update on the Ultra Classic,
Mechanic has diagnosed that the top end is in need of a rebuild and all is well with the crank with only .003" run out.
The following is taking place over the next few weeks and hopefully be all ready for when I get home in July, taking it out to 107 Cube, Heads CnC Ported and fully reconditioned, CP Domed pistons, Tman 590 cams, Barrels bored and ring end gap set, Cam Plate and oil pump, Lifters and adjustable push-rods, External Breather set up.
I will let you know how it turns out once completed.
Cheers
Locadd
Old Jun 12, 2018 | 11:16 AM
hattitude's Avatar
hattitude
Cheers
Locadd
Interesting.... I'd love to know how your mechanic got to it needing a top-end rebuild, from low oil and running hot...... ?
I'm not saying it's a bad diagnosis.... just wondering how he got there. What did he find, that may him decide the entire top end needed rebuilding, because of your symptoms.....?
Old Jun 12, 2018 | 11:55 AM
BB59's Avatar
BB59
I'd be curious how many mile were on the motor. Your symptoms "when I pulled up at a traffic light I noticed that the bike was abnormally hot and had no oil pressure showing on the gauge. I left it overnight and then restarted it, it had good oil pressure and showed no signs of getting hot " sounds like every other Twin Cam sitting at a stop light a quart low on oil in a hot climate (Philippines in April)
Old Jun 12, 2018 | 04:22 PM
Locadd's Avatar
Locadd
6th Gear
Oil sitting on top of both pistons, bad score marks and low compression in rear cylinder, lifters badly worn along with worn lobes on both cams.
Locadd
Old Jun 13, 2018 | 12:01 AM
hattitude's Avatar
hattitude
Locadd
Ha.... well I asked!
Explains your symptoms, but I would never have guessed that much damage....
Sorry the engine broke, but you'll really enjoy those new mods, your bike should run real well...!!!
Old Jun 13, 2018 | 12:32 AM
MTBIG G's Avatar
MTBIG G
That'll be a fun ride when its done. Enjoy!
Gary07
Oil Archive (no new posts)
Mar 22, 2018 01:57 PM
bigmikaele
Apr 6, 2010 04:26 PM
jarhead45
Jul 11, 2009 01:23 AM
catcher
Dec 16, 2006 10:13 AM
gregl
Aug 2, 2006 10:19 PM
