Tire balance beads?
Old May 16, 2018 | 04:54 AM
CSMHOG's Avatar
CSMHOG
Originally Posted by GittinThere
I was told today by a guy who owns a custom shop up the street that Dunlop tires come pre-balanced. Is this true or false? I think he said Metzler tires as well...
The tire may be balanced but the wheel is not ... every wheel after assembled with a new tire should be rebalanced. Unless of course you're using a product such as balancing beads or ride-on.
Old May 16, 2018 | 05:02 AM
CSMHOG's Avatar
CSMHOG
Originally Posted by propflux01
Actually the tires are balanced to a degree. The ones that are "out of spec" are usually stamped with the red "dot" on them to show the lightest side. In most balancing, you will find the wheel itself out of balance more so than the tire.
No sir, in fact the red dot means something different ... The red dot indicates the high point for both radial runout and radial force variation. As I'm sure you know, not only is it hard for tire manufacturers to make a perfectly balanced tire, it also is very difficult to make a perfectly round tire. Since it is very hard to make a tire that is perfectly balanced, some tire manufacturers apply yellow dots that indicate the tire's light balance point and serve to help you balance the assembly while mounting the tire. The yellow dots should be aligned with the valve stem on both steel and aluminum wheels since this is the wheel's heavy balance point. This will help minimize the amount of weight needed to balance a tire and wheel assembly. So usually, whenever you see a yellow dot, match it up with the valve stem.
Old May 16, 2018 | 05:44 AM
ohioflhs's Avatar
ohioflhs
I used to use Dyna Beads. I haven't balanced a tire for several changes now and I can't tell the difference. We don't have smooth enough roads around here to feel an unbalanced tire.
Old May 16, 2018 | 06:10 AM
PDB17UltraRG's Avatar
PDB17UltraRG
I’ve been running with Dyna Beads for over 10 years now never had any problems with my tires or problems in my ride. I get the maximum tire wear and great longevity out of all my tires Love them.
Old May 16, 2018 | 08:27 AM
ChromeJunkie's Avatar
ChromeJunkie
Originally Posted by nobodyknowsme
Anyone that has tried Ride On will tell you the same. Skip the beads and and get Ride On. Not only balances the tires but protects against punctures. Your welcome.
This. Not only do they protect against punctures, you won’t have a million beads all over the floor when you replace the tires.
Old May 16, 2018 | 04:39 PM
diggerv's Avatar
diggerv
Just wondering if you had a link to a motorcycle tire manufacturer that states what you have said? I couldn't find one...
It seems most manufacturers use the RED dot and Dunlop a yellow dot for the light spot.
From what I have read:
http://www.metzeler.com/site/us/en/a...dDomanda=13521
https://www.dunlopmotorcycletires.co...t/care/#tip-16
16 - Wheel Balance
It is essential that tire/wheel assemblies be balanced before use and rebalanced each time the tire is removed or replaced. Unbalanced tire/wheel assemblies can vibrate at certain speeds, and tire wear will be greatly accelerated.
All Dunlop street tires should be installed with the balance dot at the valve. Wheels may be balanced with spoke nipple weights, lead wire or self-adhesive rim weights. Consult the motorcycle manufacturer for approved wheel weights.
Old May 16, 2018 | 06:08 PM
67Shuv's Avatar
67Shuv
3oz of DynaBeads in a 205/55-16 car tire. Smooth as glass.
Old Jun 9, 2018 | 07:40 AM
kel03's Avatar
kel03
Had some Dunlop Elites put on, tire guy said no balancing required. I questioned it, and discussed on other posts. Some also said they required no balancing either. Anyhow, up at 75 mph little front balancing needed so I picked up a glass bead kit. The question is, should I put in "how many ounces", it came with 2 oz. Put in one see how it goes, or dump the 2 oz. in.
Old Jun 9, 2018 | 10:16 AM
67Shuv's Avatar
67Shuv
Put both in.
Old Jun 9, 2018 | 11:15 AM
bad tappets's Avatar
bad tappets
What does manufacturer recomend?
Edit: I rn 2 oz. in each of Fatboy tires. Smooth as glass.
