Headlight
Old Apr 24, 2018 | 09:41 PM
93EGlide's Avatar
93EGlide
Stage II
Default Headlight
On my 93 EGlide my headlight goes out when riding but spot stays on
Old Apr 24, 2018 | 09:58 PM
OkieBill's Avatar
OkieBill
Check grounds and ensure clean and tight connections , free from corrosion.
Old Apr 25, 2018 | 04:49 AM
grbrown's Avatar
grbrown
Wink
Start with your light bulb and confirm that the holder is clean and dry, also the holder makes a good connection with the bulb. Take care is it will get hot, but turn it on and see if, when jiggled, it stays bright. Then work backwards along the wires to check for sound connections, ground etc. Electrical problems of this sort are often mechanical, in other words two parts of the circuit are not working together as they should. Also check your rear lights, just in case.
flhsport
EVO
11
Jul 31, 2016 06:23 PM
Hnter1018
Electrical/Lighting/Alarm
Mar 19, 2016 06:40 AM
crawrj
Sep 22, 2014 07:05 AM
DCRANER
EVO
18
Oct 1, 2013 01:58 PM
nicko99
Sep 12, 2007 10:52 AM
