timing cover screw broken (2)
Old Apr 26, 2018 | 12:27 PM
TriGeezer's Avatar
TriGeezer
I had a tinny kind of rattle for a couple of months. Finally discovered the timing cover screws had loosened. I re-installed them with blue Locktite.
Old Apr 26, 2018 | 01:40 PM
hattitude's Avatar
hattitude
Originally Posted by skydude426
Wow dude, I thought I had it bad!
Yeah, it's a sickness.......
Old Apr 26, 2018 | 02:33 PM
Ed Ramberger's Avatar
Ed Ramberger
Originally Posted by hdman6
When i took the timing cover off I noticed it just a cover over a empty space with no access to anything because its sealed. Makes no sense to me, should just be a one piece cover. Jeff
It's hollow because the earlier bikes had cam sensors in there. Rather than change the entire design, they just closed off the holes for the cam sensors in later model covers. Allows them to sell P&A decorative covers for all years.
The holes are not tapped from the factory - the screws are self tapping. When they break off, it really sucks.
Old Apr 27, 2018 | 04:25 PM
hdman6's Avatar
hdman6
Question
Ok i plan on drilling out the broken screws and trying to re-tap it. Does anyone know what the size is? I have the box but it only shows the part number. My parts book and service book does not say either. thanks Jeff
Old Apr 27, 2018 | 06:10 PM
hattitude's Avatar
hattitude
Just FYI, my 2012 Touring Parts Catalog (#99456-12), has a hardware list in the back. It gives the HD hardware part # and then the size.
The timing cover parts are listed on page 16/17. Per that diagram, the'12 touring OEM screws are part #68042-99
Per the hardware list, part # 68042-99 is a #8-32 x 3/8 torx screw.
I should mention... I know the OEM screws for your model (CVO Flhtcuse7) are #68120-00. However your cam cover is the same part # as the other touring bikes (#25369-01B) and should then take the same size screws... your screws have a different part # because they are probably gold plated or something..
You should be able to double check my work in your parts catalog.
Good luck with the fix...
Old Apr 27, 2018 | 06:14 PM
Veekness's Avatar
Veekness
If you can't get it figured out, should be easy enough to go to your fasteners stash and thread on a screw. Or use your dies...not a biggie.
Fro
Sep 10, 2023 08:07 PM
larsfum
EVO
Oct 27, 2015 09:06 PM
JRK5892
Aug 28, 2014 05:53 PM
Deuceandahalf
Sep 23, 2010 07:36 PM
liddown
Apr 12, 2007 04:52 PM
