Front Brake lever
Old Apr 26, 2018 | 06:17 PM
bigpappa160's Avatar
bigpappa160
Default Front Brake lever
Hi Everyone, been away from the forum for a while! But I have a question on front brake lever. I have a 07 Ultra Classic and the brake lever is like loose, like it doesn't just flops around I can just move it up and down, is there anywhere I can tighten the lever. Also, I noticed that my tail light doesn't come on when I press rear brake foot pedal, but it does come on when I pull the front brakes any suggestions?
Old Apr 26, 2018 | 06:34 PM
Veekness's Avatar
Veekness
Front brake: likely a worn pin bushing, PN 45423-96. Made of plastic, I believe, prone to wear.
Rear brake: likely the sending unit, PN 72023-51E.
Both parts available at your dealer. However, if you choke at the twenty buck price of the latter, consider going to your local auto.parts store and getting a common 1/8-NPT brake switch with two spade terminals for about a third the cost.
If you don't already have one, get a factory service manual before you turn a wrench!
Old Apr 26, 2018 | 07:30 PM
SnoRider's Avatar
SnoRider
Veekness your on point man.
Old Apr 26, 2018 | 07:36 PM
Veekness's Avatar
Veekness
Thank ya, sir! With luck, OP will be out well less than a double sawbuck!
Old Apr 27, 2018 | 11:06 AM
bigpappa160
Thank You, Veekness! I will check those out
Old Apr 27, 2018 | 04:47 PM
BackRoader's Avatar
BackRoader
What he said! I had to change out my sending unit last summer. Simple job. Its located on the right side, near the frame in the tranny area. It's activated by brake fluid pressure, so when you open the system you will get air in the line. After install a rear brake bleed will be needed. What the heck, good time to purge out the old fluid anyways.
Old Apr 27, 2018 | 11:01 PM
Veekness's Avatar
Veekness
Do it right and no bleed will be required...I've done several and never needed to bleed...but, if you do need to, I agree that you should flush. And as long as you're hot, bleed the fronts too.
Old Apr 28, 2018 | 08:54 AM
ultra_classic's Avatar
ultra_classic
^^^^^^^ this
bglaze
Aug 14, 2013 05:55 PM
Horses 4 me
Jun 28, 2013 08:23 PM
NOLAMike
Jan 22, 2009 08:06 PM
Alan 123
Mar 28, 2008 08:51 PM
98sportyil
Jan 21, 2008 06:06 PM
