Inner fairing brackets
Old Apr 29, 2018 | 10:34 AM
hotwheels57's Avatar
hotwheels57
Default Inner fairing brackets
Inner fairing brackets broken on a 2008 SG. Whats the best replacement. After a little research should I get a repair kit or just replace the whole bracket ? I'm sure there will be mixed reviews.
Old Apr 29, 2018 | 10:39 AM
dawg's Avatar
dawg
They changed in 09 so you could either get the HD replacement, could get the aftermarket ones like the heavy duty plastic, or could fix the ones you have with your own crafti work or buy a repair kit. It’s all subjective as to what you want. Were it me, I’d buy the HD bracket.
Old Apr 29, 2018 | 10:45 AM
hdman6's Avatar
hdman6
Thumbs up
If it is broken in the usual spot its a easy fix. I had a 2008 ultra. the Left bracket broke on the top of the bracket. what i did was drilled a couple of hole and put a plate on connecting the 2 broken side together. tightened it up nice repainted it. Worked fine and cost next to nothing for the fix. Other option is to remove all the stuff and put in new brackets. If you go that route may as well get the aftermarket ones that don't break. do a search on the forums here that's what i did when mine broke and i found the answers i needed. Jeff
Old Apr 29, 2018 | 12:26 PM
leachman's Avatar
leachman
hardware store flat or angled bracket depending on where yours separated. Well under $10 fix...I did mine few years ago and still lasting strong.
soos
Feb 27, 2011 10:33 PM
iclick
Jan 29, 2011 10:43 AM
maineultraclassic
Jul 11, 2010 09:13 AM
electra glide
Feb 23, 2009 10:56 AM
FastHarley
Jan 19, 2008 09:00 PM
