Break squeal
Old May 11, 2018 | 02:47 PM
Jamey Longriders MC Irish's Avatar
2nd Gear
Default Break squeal
put a 21 inch fat spoke dna wheel on bike and new pads and the breaks squeal very loud. Any advice to make stop squealing.2016 road king
Old May 11, 2018 | 03:24 PM
vizcarmb's Avatar
vizcarmb
did you put brake disc quiet behind the pads before installing or lube up the brake components????
Old May 11, 2018 | 03:36 PM
2nd Gear
No I did not I will take off and try thanks
Old May 11, 2018 | 04:57 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
^^^^^ That^^^^^
Old May 12, 2018 | 07:47 AM
nhrider1's Avatar
nhrider1
I tried everything to get rid of brake squeal. Disk brake quiet on the rear of the pads worked for a while....but eventually returned.
After much research and frustration I used high temp grease on the contact area on the back of the pads. It works, and the squeal never returned.
Its caused by high frequency vibration between the pads and pistons and the grease eliminates it.
Old May 12, 2018 | 07:53 AM
Mac10's Avatar
Mac10
I did the same on my RK for the rear. Used high temp ball bearing grease on rear of pads and also on the pin. Lightly sanded the glazed areas on the rotor. No squeals again.
Old May 16, 2018 | 05:28 PM
elPrez's Avatar
elPrez
I just installed new rotors (all 3) on my 05 Ultra. I only had about 2,000 miles on the brake pads so I didn't replace those. The pads never came off of the calipers but the front is singing like crazy when I come to a stop. Would removing the pads and applying the disc quiet work for me? I'm going to remove the pads and scuff them up a little to take the glaze off.
Old May 19, 2018 | 10:49 AM
elPrez's Avatar
elPrez
Well I did it today, cleaned everything out with disc brake cleaner and applied disc quiet on the back of the pads...now if it every stops raining I'll get to see if it helped!
Old May 19, 2018 | 11:17 AM
lightweight bob's Avatar
lightweight bob
Default SBS anti-noise brake pad shims
Use these - cut to size - but make sure they cover the pad backing plate where the pistons hit. They also give your brakes a better feel imo.
Amazon Amazon
http://uk.sbs.dk/products/street/accessories
I never install pads without them.
Marklovell90
Sep 18, 2018 10:32 AM
JKat316
Jul 5, 2018 05:50 PM
RollTideRoadGlide
Aug 21, 2016 07:36 PM
Craig C.
Aug 11, 2008 04:20 PM
chfcheese
Jul 11, 2007 10:36 AM
