2006 FLHTP Police only starts if jump Solenoid
Old May 14, 2018 | 03:12 PM
casey8905's Avatar
casey8905
6th Gear
Default 2006 FLHTP Police only starts if jump Solenoid
Got a 2006 FLHTP and a 2008 FLHTPI electra glide standard police edition bikes they both fire up and run but only by jumping the starter solenoid wire to the main post on the starter.
Im not very good with wiring but I hear the relay click once when I turn the ignition on it shows full voltage at all three wires coming out of the relay except for the black which i assume is ground. but only shows .03 volts on the green wire to the solenoid and no change in voltage when I hit the start button and nothing happens.
Im so lost I dont know if there is something they tapped into on the harness that they left unhooked it has a relay on the right side of the bike hanging with two wires coming out of it black and purple that are cut. So many wires cut from where they took off the lights, horn siren etc..
Any help or point me in the right direction would be greatly appreciated. Thanks
Old May 14, 2018 | 04:53 PM
hbsoldier3's Avatar
hbsoldier3
I don't mean to be an ***, but you are pulling the clutch level in correct?
Old May 15, 2018 | 05:47 AM
Campy Roadie's Avatar
Campy Roadie
That ^ first.
Try it in neutral with the start button before going any further.
Old May 15, 2018 | 10:05 AM
casey8905's Avatar
casey8905
6th Gear
No i understand sometimes we miss simple things but I have tried pulling in the clutch while in neutral too but still the same thing. The starter relay only clicks once when the ignition turns on but nothing happens when I press the start button. Ive swapped the relay already as well.
Old May 15, 2018 | 11:17 AM
RoadKing_Bob's Avatar
RoadKing_Bob
I had a 06 Roadking that while riding down the road decided to run the starter continuously, it turned out to be the start switch on the handle bar, the replacement switch will need to be soldered into place, not extremely difficult to do. Could be a similar problem area.
Old May 15, 2018 | 12:07 PM
casey8905's Avatar
casey8905
6th Gear
I purchased a whole right control switch assembly with the kill switch and start button off eBay and still had the same effect ):
Old May 15, 2018 | 08:56 PM
14GuineaPig's Avatar
14GuineaPig
https://serviceinfo.harley-davidson.com/sip/vehicle/lookupForm
Go
to the HD Service Info Portal and enter you VIN. You should be able to get the wiring diagrams & view the owners manuals for your bikes.
Old May 16, 2018 | 12:25 AM
ses's Avatar
ses
Did you check the starter relay? Not sure an the police bikes but there are two relays under the seat, one is for the starter.
Old May 17, 2018 | 12:29 PM
casey8905's Avatar
casey8905
6th Gear
Yep have replaced the relays but same outcome. I was wondering if it isnt something they cut that they tapped into since both bikes do the same thing. Thank you for the lead to the wiring diagrams as well. Someone told me it sounds like a bad ground so going to try and just trace everything back and see what happens.
Old May 17, 2018 | 12:36 PM
Tom84FXST's Avatar
Tom84FXST
I believe the police bikes also have a kickstand switch...
