?? on changing road king handbars
Old Jun 23, 2007 | 11:52 PM
jrbean1's Avatar
jrbean1
Default ?? on changing road king handbars
I am thinking about change the 04 RK handbars. How do I remove the cover over the center of the handlebars? Is it the same set up under the cover as the sportster modles? I have changed the sportster but not on the RK yet. Am still waiting for my shop manual to come in.
Thanks for any info.
JR bean
Old Jun 24, 2007 | 12:53 AM
KSSportster's Avatar
KSSportster
Default RE: ?? on changing road king handbars
Just had to do this to adjust my bars. I think I searched on here for the correct procedure. I do know that I had to remove the headlight ring, headlight, andlittle cover on the fork locking mechanism. You also have to loosen two nuts that hold the little trim thingy on the center of the nacelle. PLease forgive my techincal names!
Old Jun 24, 2007 | 01:17 AM
Sol's Avatar
Sol
try this link
http://www.moccsplace.com/images/harley/hbar/hbar.htm
Old Jun 24, 2007 | 01:30 AM
harleyboy67's Avatar
harleyboy67
6th Gear
You have to remove the cover over the fork lock, remove the two screws. Remove the headlight ring, headlight and the two retaining nuts that hold the chrome molding on the top of the headlight nacelle before you can even remove the cover over the handlebars. What kinda handlebars are you changing to? Keep in mind it is recommended that the handlebar clamp is changed a solid one rather than the two split ones that currently hold the handlebars. Hope this helps.
Old Jun 24, 2007 | 05:23 AM
PapaTravis's Avatar
PapaTravis
What he said. ^^^^
Old Jun 24, 2007 | 05:55 AM
Oilslick's Avatar
Oilslick
Have a look at this http://mysite.wanadoo-members.co.uk/hhog/rkbarswap.pdf.
or this http://www.harleyhog.co.uk/turbosmoke.htm
Might be of help to you.
Old Jun 24, 2007 | 06:05 AM
PapaTravis's Avatar
PapaTravis
Oilslick, that 'mysite' link sure does look like a lot of good info. Thanks for the link.
Old Jun 24, 2007 | 06:15 AM
Oilslick's Avatar
Oilslick
Cheers PT.
Old Jun 24, 2007 | 06:50 AM
Fearless1's Avatar
Fearless1
I just changed mine and it is not to bad of a job I rode for a week with the 2 little handlebar mounts untill I got the solid one it worked fine. I went with 4 inch risers with 1 inch pullback and buckhorn bars, I had to modify the chrome handlebar cover with the dremel to allow the new risers to come up thru but not that bad of a job. I have used the buckhorn bars on almost all of my bikes and just love the riding position they give me they allow me to kick back on the highway pegs without reaching out to hold the bars I hated the stock bars they gave me a backache and neckache everyday. DON'T OVERTIGHTEN THE SCREW HOLDING THE HEADLIGHT TRIM IT WILL BREAK OFF THE HOLDING TAB.
Old Jun 24, 2007 | 10:37 AM
masterblaster's Avatar
masterblaster
