I'm about to change out the rotors on my '05 Road King. I never did them before, but it looks pretty straight forward. And tricks I need to know to get the old bolts out?.,,
Those new bolts are damned expensive! Can get by without them?
Technically, the FSM states to replace front rotor bolts each time, but the rears can be used 3 times. I know some folks that have reused the fronts without incident. The front brakes get used much more than the rears generally speaking. Its up to the individual and the risk theyre willing to take.
Well, yes, but the load on the front is spread across 10 bolts, while the rear is across 5.
I'm not worried about the bolts shearing off, once installed. I'm thinking more about the bolts breaking as I torque them?
Just did mine on a 2011 with 86k - easy peez - don't forget new pads at the same time...New bolts with some red lock tight. But if you need to you could use the old ones....
Doubtful that they will break, it is just good practice. I work in the high performance engine industry and we typically replace certain bolts upon a yearly freshin up. High heat and load is typically a bolt to replace. just my opinion of course.
