neutral issue still
It's been awhile, and I can't remember which way I moved the release, or I'd tell you; but this method definitely worked.
OP, that might provide a quick fix for ya, but if it doesn't, were it me, I'd replace the clutch plates. I used Barnett Kevlar, but you do the research for yourself and decide, should ya decide to go that way. If you're absolutely CERTAIN that the clutch is adjusted correctly, I'd say a warped plate, either the steel or abrasives, is your culprit. When I replaced mine, I got the kit that omitted the steel plates, since I was confident that they were good...but in your case, I'd get the complete set.
Good luck with yours
