magneti marelli problems
Old May 29, 2018 | 06:17 PM
rustynail81's Avatar
rustynail81
Stage II
Default magneti marelli problems
2000 serg cvo just rebuilt. Bike craps out between 2800 - 3200 revs on load. On the hammer it's ok??
Old May 29, 2018 | 06:39 PM
Budda109's Avatar
Budda109
Take it back to the guy who rebuilt it. Ask him the same questions? If you rebuilt it. Read up.
Old May 29, 2018 | 09:34 PM
rustynail81
Stage II
We just did motor not efi, tuned best we could system has power commander. Lookin' to see if anyone had this problem and how did they rectify.
Old May 29, 2018 | 10:19 PM
im's Avatar
im
If bike ran correctly before service then problem might have occurred during service.
Like a loose part or a part that was installed in a different position.
Rebuilt is a word that can mean many things so it is difficult to direct a resolution based on the limited information available.
What does rebuilt mean to you?
Words like craps out are difficult to understand...What exactly does that mean to you?
What does on the hammer mean to you?
If you have a problem between 2800-3200 RPM (like a dead zone/no throttle response) then it could be a problem with the power commander map in that range or maybe the throttle position sensor.
Consider review of throttle position sensor for a dead spot.
If you have a power commander then you can review throttle position on a laptop and you can re-verify throttle position with a digital voltage meter.
Below is a link to help you identify parts for your 2000 Screaming Eagle Road Glide.
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
Old May 30, 2018 | 03:21 AM
tfi racing's Avatar
tfi racing
Carb conversion is your THE only solution that will not result in a fiery death to you and all of your family. Stromberg carb and flint point set from an early 40's flathead Ford is your best option. Sorry,but had to be the first in line...
Old Jun 1, 2018 | 08:44 AM
Razorback's Avatar
Razorback
Converted my '01 to Mikuni HSR42. Here is a "kit". http://store.4x4tuff.com/hs26.html click on the instructions. You will need a sub harness from HD also. RIvera makes a cruise control bracket for it also, easy install.
Amazon Amazon
EDIT: I still have all the old Marelli stuff if needed.
Crzyfin
Feb 14, 2019 08:46 AM
louisianaSVT2001
Jul 11, 2017 03:20 PM
dgm410
Apr 21, 2013 12:52 PM
bmkbailey
Nov 22, 2012 09:07 AM
rigid01
Jun 22, 2011 07:36 PM
