Checking tire pressure
Old Jun 4, 2018 | 11:14 PM
  #31
SnoRider's Avatar
SnoRider
I will admit...I only check mine about twice per year, which, I actually did today after adding air last week. Need to get into a better habit. I can tell when they are about 5lbs too low. I bought an extender off amazon. It came the same day I ordered it. One end screws onto the stem, then I fill the tire with a bicycle pump. Bicycle pump has an accurate gauge. Peice of cake best 10 bucks I’ve ever spent.
Old Jun 5, 2018 | 12:34 AM
  #32
davewear's Avatar
davewear
Really? All this bitching about checking tire pressures? It’s kinda a good thing to do, maybe you picked up a screw and have a slow leak? Anyway, i check at least once a week and getting down on my knees to do it is no biggie....
Old Jun 5, 2018 | 01:17 AM
  #33
SnoRider's Avatar
SnoRider
I didn’t see a whole lot of bitching going on in the thread....one guy said it was a pain in the *** but pretty much everyone else offered some sort of solution to something that actually is a pain in the ***. But, We are all so much smarter now knowing that you don’t mind checking your tire pressure.
Old Jun 5, 2018 | 11:12 AM
  #34
davewear's Avatar
davewear
glad to help! Also I’m going to check out that Fobo.
Old Jun 5, 2018 | 12:43 PM
  #35
GregGillette's Avatar
GregGillette
With the monitor I purchased above, I do a visual pressure check on every startup and will get alarm if either tire drops below a set pressure. The phone app option is cool, almost went that route too but want my phone put away when riding. If you use to stream music or have paired to radio for calls, then the fobo would be good
Old Jun 5, 2018 | 12:50 PM
  #36
Z's Avatar
Z
Originally Posted by cncmike
Next time you change tires have right angle valve stems installed. It makes it so much easier
Great idea.
Old Jun 5, 2018 | 04:43 PM
  #37
nobodyknowsme's Avatar
nobodyknowsme
Thumbs up
Originally Posted by GalvTexGuy
I had the KurveyGirl angled valve stems installed last tire change. Much easier to check tire pressures.
https://www.kurveygirl.com/shop/prod...43kvbp2th5tgq7
If I could give you more than just one thanks I would. Can't tell you how much time I have spent looking for these or for how long. Have searched and searched for the correct size and almost everything suggested 10 mm with very little mention of 11.3 mm, which I am now reasonably certain is the right size?
I am not that lazy that I need an app or some gizmo that tells me my pressure is low. For me 2 PSI off is low so maybe I am ****. Well, yes, I am **** about my bikes PSI. Forever, since my first HD touring bike I have simply wanted an easier way to check and add air. These affirm the correct size and I will be ordering them.
Thinking about this today I decided to use my smartphone as opposed to my computer and it did come up with this site, but I was searching for HD 90 degree info and it took me there but a PDF of a size chart.
THANK YOU!!!!
Old Jun 6, 2018 | 09:22 AM
  #38
WMJ's Avatar
WMJ
Originally Posted by GregGillette
Preferred not having to have phone app on and in view. Real time monitor and alarms for changes.
Attachment 594449
I had these & returned them because they wouldn’t update. Went with Fobo and no problems to date.
Old Jun 6, 2018 | 12:24 PM
  #39
GregGillette
I had issues with 1 of the senders until it detected rolling movement then could pair it fine. Not a perfect device and a bit odd of a menu system but its been rock solid since I installed
Old Jun 6, 2018 | 12:36 PM
  #40
KCFLHRC's Avatar
KCFLHRC
I like the idea of the TPMS as long as they are reliable. And if you aren't checking tire pressure one way or the other before each ride you aint real smart. I know, I know, as long as the stereo is working I'm good to go, well, think again. A blow out on a motorcycle is a whole lot more exciting then in a car or truck.
