Piston size question.
Old Jun 1, 2018 | 08:42 PM
6 gun's Avatar
6 gun
Originally Posted by Kingglide549
Just for fun here, -, i advised him to measure the bore B4 choosing a piston.
It does no good to vasulate, postulate, guess about what might work without the facts.
The fact is the absolute cylinder size is what will dictate piston size.
Carry on.
I bought my pistons first, and the machine shop miked my pistons, and then bored my jugs to match, sixty thousand miles and counting says it was a good plan.
Old Jun 1, 2018 | 08:44 PM
Kingglide549's Avatar
Kingglide549
As a precaution, it is wise to know if the bore will clean up first so one does not waste their money.
Carry on and do it any way you want.
Old Jun 1, 2018 | 09:03 PM
Taggs's Avatar
Taggs
Having punched (machine bored) many engine bores over the years, your call is the wisest. Until the machining is completed there can be cases where the boring step will not clean up the cylinder walls at the desired oversize,for the already purchased piston.
Old Jun 1, 2018 | 09:09 PM
Kingglide549
It would be quite embarrassingly expensive to send over your ceramic coated, molly skirted, firewalled, balanced stuff and have the shop say
go get a bigger set!
The wallet would feel embarrassed!!
Old Jun 1, 2018 | 09:21 PM
6 gun's Avatar
6 gun
Well I finally get what you are saying, and it would be crazy to bore a jug and then not have enough meat left to clean up the jug after the bore, and have to buy new pistons and jugs as well.
Old Jun 1, 2018 | 09:26 PM
Kingglide549
Yup!
Most of the time there is several OS one can go too..
.If there is a big score/scatch then the bore could still be done-
Just bigger and a larger piston then one that was supposed to go in the fresh hole
Old Jun 1, 2018 | 09:39 PM
838's Avatar
838
Yup!
So could the fresh hole be intentionally bored to fit the 3.885 piston if the cylinder has the capability of being bored to a max of 3.9375 (98", 107")?
Old Jun 1, 2018 | 09:50 PM
Kingglide549
The final answer is between you and your machine shop, or a machinest on here.
I would say no.
But I am not the resident expert.
Old Jun 1, 2018 | 10:59 PM
0ldhippie's Avatar
0ldhippie
While measuring boresize is nessicary if you are trying to go with smaller oversizes, few folks are doing that. They want the biggest oversize for performance. Pretty much any 88”/96”/103” jug can be bored to 98”/107” size. There must be some pretty serious bore damage to not clean up at that bore...or a way offset sleeve where the overbore would get into the cylinder. Both rare.
Old Jun 1, 2018 | 11:14 PM
838's Avatar
838
Yes, but can that 88,96 jug be bored (specifically and intentionally) to fit a 95,103 (3.875 big bore) with a .010 oversized piston?
So bore the cylinder with the specs of 3.885 to accommodate a 3.885 piston?
