Piston size question.
Old Jun 2, 2018 | 08:25 AM
Taggs's Avatar
Taggs
Originally Posted by 838
Yes, but can that 88,96 jug be bored (specifically and intentionally) to fit a 95,103 (3.875 big bore) with a .010 oversized piston?
So bore the cylinder with the specs of 3.885 to accommodate a 3.885 piston?
Not really clear on just what you want to accomplish on your engine but, if you read the requirement specs on the piton set you show in your first post might answer some oh your questions. It states, “ this piston set should only be used with a big bore set of jugs”. If that’s what you have, your good to use whatever oversize piston set for the 1550 you wish. That is providing the cylinder wall bore cleans up within that spec oversize piston set. Like mentioned, it could be at, .010, .020, .030. Much beyond that, it’s both a matter of if there’s even a larger oversized available and the question of the barrel thickness a consideration. Your engine manufacturers provide for their parts producers exact specifications on the max bore recommended. In my shop we used Federa Mogul provided text information.
Old Jun 2, 2018 | 10:06 AM
Bingee's Avatar
Bingee
If you bore your cylinders to 3.885, the correct piston size will be 3.875 +0.010. That means the pistons are intended to fit a
3.875 cylinder oversized 0.010.
Old Jun 2, 2018 | 01:07 PM
ratpick's Avatar
ratpick
Yes. Not sure why all the confusion and obfuscation on this point.
Old Jun 2, 2018 | 02:33 PM
bad tappets's Avatar
bad tappets
OP - The kit you are looking at is for a 1550cc motor (95 ci) bored 10 over stock bore size of 3 7/8". An overbore kit, is designed for when your cylinders get worn and you want essentially keep the stock motor size; you bore 10 over and use an overbore kit, such as the one you showed. The bore needed for this kit would be 3 7/8" (3.875) + .010" = 3.885". And yes, a 95 can easily be bored 10 over.
Boring a motor to a larger displacement, is a whole 'nother deal. If you want to increase displacement, bore the cylinders out. A 95ci motor is a TC88 bored from 3 3/4" to 3 7/8".
Your post says "if I were to have my 88" cylinders bored would it make a difference?" If you are looking at a 1550 kit, that is for a 1550cc of 95 ci motor, a TC88 is 88ci or 1450cc; not a TC88.
Figure out what you have, what you want, and go from there. Several other good posts about matching pistons to cylinders.
Old Jun 2, 2018 | 02:42 PM
838's Avatar
838
OK. I have a stock 88". These .010 over pistons were going to be used in a different 95" (high mileage bike, so I'm guessing for worn cylinders as you speak of). They were never used and was told I could have them. So, if my 3.750 88" stock jugs could be bored to 3.885 (not 3.875) I could have a 95" for the cost of a cylinder bore.
Old Jun 2, 2018 | 02:46 PM
bad tappets
Yes, correct. But do follow other posters advise on size matching.
Old Jun 2, 2018 | 05:16 PM
838's Avatar
838
Yes. That seems to be the best choice. Thanks everyone for taking the time to voice your knowledge on the subject. My (non-machinists) logic thinks that if the cylinders that I have are capable of being bored from 3.750 to 3.9375 then they should be fine to be bored from 3.750 to 3.885... we'll see Monday.
Old Jun 4, 2018 | 04:45 PM
838's Avatar
838
Well my (non-machinists) logic was, in fact, logical. 3.885 will be just fine!!!
Old Jun 4, 2018 | 06:55 PM
Taggs's Avatar
Taggs
Just curious. Mind sharing your source for this claim??
Old Jun 4, 2018 | 07:30 PM
838's Avatar
838
PM sent.
NELS
Shovelhead
Jan 1, 2018 01:18 PM
djbarker
Engine Mechanical Topics
Jul 12, 2011 09:44 PM
swensos
EVO
Mar 24, 2011 01:14 PM
cruiser08
Sep 14, 2008 10:54 PM
wuudbee
Exhaust System Topics
Jul 22, 2006 04:17 PM
