howling noise, H E L P
Old Jun 24, 2007 | 11:29 PM
bluebagger's Avatar
bluebagger
Default howling noise, H E L P
Last month I had to replace my back tire. While they were doing it I had brake pads put on the rear. Now here is the problem which could be a fluke. On the first good rideI went on and after about 20 miles I herd a howl or it sounded like a wheel bearing going out if it was a car. I only noticed it because I coasted at about 40 miles an hour and heard the sound loud and clear. When I applied breaks, no change still howled. The shop I went too is a local Hogg shop which has a good rep. Did they put the axel bolts to tight ( I don't know, I'm not a wrench), orwas it theway the pads were put on or is it coming from the gear box or what. It is an 07 ride. Hell I'm confused. I will probably have to go into the local Harley shop. However, on Monday, tomorrow I will be taking it back to the shopwhere I had the work done, Ineed them to assure me it was not caused by them,if it wasthey can fix itorI'll be getting my a_s chewed out by the Harley wrench. Can't win now days, I won't even start about the I R S.
Old Jun 25, 2007 | 11:01 AM
DocHarley's Avatar
DocHarley
Default RE: howling noise, H E L P
I'd like to hearthe IRS story.
Old Jun 25, 2007 | 11:07 AM
Hogtoad's Avatar
Hogtoad
Just a thought, maybe it's the tire. What kind of tire was installed?
Old Jun 25, 2007 | 11:26 AM
Qball's Avatar
Qball
Have your passenger shut her legs.......j/k
Old Jun 25, 2007 | 01:09 PM
flharleycop's Avatar
flharleycop
Sounds like a belt whine have the dealer re align the reat tire. That happens sometimes after getting a new tire.
Old Jun 25, 2007 | 01:31 PM
Gutman's Avatar
Gutman
ORIGINAL: flharleycop
2007 use eccentrics. Rear wheel alignment cannot be off. Check belt tension before going to dealer. Match tension with lines in beltguard cutout. Check tension after. Ride bike at speed then pull in the clutch. This will remove all belt / clutchdrive noises. Still whine? Take it back, I'm sure they will look at it. I haven't seen any "new" wheel bearings go bad since released.
Old Jun 25, 2007 | 01:32 PM
smknflms's Avatar
smknflms
..tire is rubbing, might have wheel spacing off, stick a finger between fender and tire on both sides and see if there is adequate space.
Later
Old Jun 25, 2007 | 09:43 PM
bluebagger's Avatar
bluebagger
Thanks for all responses, I like the one about my wife's legs. I'll tell her to leave the peg leg home next time.
I took it back to the wrench today, he is looking into it. If he is as good as others say he should check all alignments first, we'll see.
Old Jun 25, 2007 | 09:56 PM
Mr Wonderful's Avatar
Mr Wonderful
It's the belt! [:@]
skiddd
Oct 4, 2014 02:48 PM
brianstephenson@btinternet.com
Wheels/Tires
May 1, 2012 02:10 AM
Beercan321
Jul 10, 2008 10:01 AM
jefnightrain
May 7, 2008 01:41 AM
beauty
Oct 15, 2007 10:54 AM
