MY Bike will not move
Old Jun 25, 2007 | 07:40 AM
curmudgeon's Avatar
curmudgeon
Default RE: MY Bike will not move
That's what you get for starting a project on Sunday night ; )
Old Jun 25, 2007 | 08:14 AM
Taterdog's Avatar
Taterdog
ORIGINAL: jdtest
Crisis over. Thanks.
Jd, let us know what the problem was. Only way we learn.
Old Jun 25, 2007 | 09:05 AM
choochoo's Avatar
choochoo
I use a commercially available offset boxend wrench. Most good auto parts stores carry these as an individual wrench.
Added plus withis is you can see the nut and allen bolt that you're tightening.
I have complete set myself, but then I was a mechanic full time for 30+ years.
Old Jun 25, 2007 | 10:42 AM
RonH's Avatar
RonH
On the Fix My Hog DVD they don't use a special socket or anything. Once the adjuster is set, they just torque down the outer lock nut. That's what I've done and had no problems.
Old Jun 25, 2007 | 12:42 PM
Domestic Violence's Avatar
Domestic Violence
the problem was that he didnt start the bike up
Old Jun 25, 2007 | 01:21 PM
jdtest's Avatar
jdtest
I followed the sure fired directions posted on the site. In doing so I pulled the clutch lever in which allowed me to over adjust the bolt. So then it did not work the first time I just kept adjusting the bolt not noticing that when I was turning the bolt the center plate was moving. So after walking away from the bike for about 15 minutes as to not cause any damage to the bike or my garage. I was coached through the procedure via the phone and it all worked out.
Old Jun 25, 2007 | 02:29 PM
Gutman's Avatar
Gutman
ORIGINAL: RonH
Here's the method I use - and got when someone here on the forum posted it. Works every time for me:
CLUTCH ADJUSTMENT
Here is an almost fool proof method for clutch adjustment. It takes the guesswork out of the "feel" for the adjuster.
Once you have opened up the derby cover and are ready to proceed...
1)Collapse the adjuster on the cable sleeve all the way.
2)Pull the lever against the bar and hold it there with slight force.
3)Turn the pushrod adjuster bolt in while holding the lever against the bar lightly until it starts to force the lever away for some distance. (Do this more than once to get the feel). While keeping light pressure on the lever back the adjuster bolt out just until the lever touches the bar again and then another little bit, about 1/2 turn , then lock it.
4)Adjust the cable freeplay at the lever for 1/16" free play.
You should be good to go .
Always adjust the clutch on a cold bike for best results.
**It's better to adjust the clutch so that it starts to grab at least an inch or more from the bar for complete disc separation, which translates into better/quieter shifting.Using this method, you can "feel" where the lever is going to grab with a little practice.
Buy yourself a cheap 11/16 deep well socket and weld a nut on top of it. This makes the perfect tool for the adjuster lock nut. You can then use an Allen wrench inside the socket and a wrench on the nut you have just welded on. Makes it a lot simpler.
This "Sure Fire" method, lesspulling in the lever and keeping tension on it is awesome. I also call it the "Factory Recommmended Pocedure" as read in the Service Manual. Pulling in the lever will cause the end to come out. Don't mess with it. The wrench is sure fire. I have one just like it, works great.
Damien Bessent
Nov 6, 2015 07:10 AM
DJFriar
19
Apr 8, 2015 02:16 AM
Pmariner
Jan 13, 2008 02:54 PM
jdtest
Jun 25, 2007 09:35 PM
smokin13
Mar 15, 2007 08:53 PM
