while riding my bike almost died and starting making a clicking rattling noise in the front of motor tried to die couple times on the mile ride home when I shut it off a restarted after a few seconds it lost all oil pressure what could be wrong
Welcome to the Forum.
How many miles on it, did you check the oil, when was the last time it was serviced and by who, how long had you been riding before it started, and what modifications have you made? Might want to give any other information that could help.
Bike has about 32000 miles bought it about three weeks ago bike was serviced then oil level is low which is odd since it was just changed only put about 400 miles on it ran great no problems until today was only a mile from house when it started
If oil is not getting through, you will get clanking lifters and/or clanking top end. Could be stuck relief valve, plugged feed hole/oil pump issue, etc. Even though the 07 has hydraulic tensioners and they’re supposed to last much longer than the spring tensioners on the 99-06 TC88’s, you still could have an issue with them and resulted in what caused the oil problem
Who did you buy it from - the Dealership or an individual. No way oil level should be low after 400 miles. How low was the level?
