Reduce engine heat
Old Jun 18, 2018 | 11:42 AM
DK Custom - ST's Avatar
DK Custom - ST
Platinum Sponsor
Originally Posted by Notgrownup
when doing a tank lift will it still allow my seat tip to go over my tank.?
Yes, it will. It will be a slighter tighter fit for the seat.
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
http://i1088.photobucket.com/albums/i339/DKCustom/Links/Sig1-8-14_zps9d8aff35.jpg
Old Jun 19, 2018 | 06:04 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
For me, getting rid of the cat made the biggest difference on heat reduction.
Old Jun 19, 2018 | 11:42 AM
mcain49's Avatar
mcain49
Stage 1, oil cooler, cooling fans, cat removal, and full synthetic oil worked for me.
Old Jun 19, 2018 | 02:41 PM
Notgrownup's Avatar
Notgrownup
Going from a 96” to a 103ho the heat went up quite a bit, the crotch cooler helps , I might do the tank lift from DK.
Old Jun 19, 2018 | 06:11 PM
bklynbob's Avatar
bklynbob
You have a cam that has -8 degrees overlap. Get a cam (Andrews 48 is a good start) and have it tuned with a TTS or a power vision. Let the heat out,all the others are band aids.
Old Jun 20, 2018 | 07:01 AM
scott7d's Avatar
scott7d
I'm sure it's been mentioned, but a tune should be the number 1 defense against heat. It is addressing part of the problem rather than just putting a band-aid on it. Not to mention the other general benefits you get from a quality tune.
I take a lot of big trips throughout the course of the year and have a high compression motor. So I also added Love Jugs Mighty Mite fans which provide additional cooling while riding under 50mph. My EITMS never kicks on anymore during construction sites and stoplights. Two friends who have the ability to check oil temps while riding can watch their temps drop after turning on the fans. Not to mention keeping head temps lower, which is sometimes confused with oil temps.
sandesh
Nov 22, 2017 08:35 PM
roysclockgun
May 26, 2017 03:47 PM
7Springer
Milwaukee Eight (M8)
Mar 6, 2017 07:56 PM
Bart van der Meulen
Dec 28, 2012 10:01 PM
b5mac
Apr 26, 2007 10:56 PM
