Fairing bolt receptable pulled loose
Old Jun 16, 2018 | 08:23 PM
No Tyme's Avatar
No Tyme
Default Fairing bolt receptable pulled loose
I am having trouble securing the "nut" end for one of the top fairing bolts at the windshield. It is that brass piece that is pressed into the inner fairing that has pulled out. I have tried "duraglass" which is my go-to fixer for things I can't seem to get to hold, but it didn't work. I mixed up some JB Weld and I am waiting for that to set up and see if that works.
Is there any fix's that anyone can pass along?
Old Jun 16, 2018 | 08:43 PM
03 Fatboy's Avatar
03 Fatboy
Do a search, you will find the answer.
Old Jun 16, 2018 | 09:12 PM
FXDXTSport's Avatar
FXDXTSport
The dealer has replacements that screw in rather than press in. Common problem. If you buy the replacements from the dealer you will see they have a slot in them. The slot is not to be used to screw them in, it is for allowing threads to be cut. Put the screw into the replacement, screw it into the inner fairing until tight and then remove the screw.
Old Jun 16, 2018 | 10:44 PM
No Tyme's Avatar
No Tyme
I found these on fleabay, didn't know about this fix.
https://www.ebay.com/i/251635600325?chn=ps&var=550539625195
Old Jun 17, 2018 | 01:06 AM
stro1965's Avatar
stro1965
Your JB Weld fix should work just fine.
Old Jun 17, 2018 | 06:30 AM
Hawk66's Avatar
Hawk66
I've used the screw in replacement inserts. They work fine. Came with an installation tool.
Old Jun 17, 2018 | 07:52 AM
SiggerTX's Avatar
SiggerTX
I have a set of the screw ins around here somewhere. Jb weld has been working fine for 2 years though.
Old Jun 18, 2018 | 07:26 AM
whyrzwaldo's Avatar
whyrzwaldo
Been a while now but mine is still holding with the JB Weld fix....This seems to be the most common solution if you don't want to purchase the replacement inserts.
Old Jun 18, 2018 | 03:12 PM
kevin_n's Avatar
kevin_n
Used JB weld on my old 04 and my wife's 13 sg and no issues at all. Sold the 04 but my wife's have been held in for 2 years now wth JB weld.
OldSarge
Oct 26, 2013 10:36 PM
casique
Mar 13, 2012 04:20 PM
Jags93
Jan 4, 2011 03:51 PM
Cheese Head
Aug 30, 2010 12:38 AM
rlb5857
Apr 19, 2007 11:24 AM
