Progressive monotube setup
Old Jun 26, 2018 | 12:19 PM
  #41
HM_SanDiego's Avatar
HM_SanDiego
Originally Posted by MikeTD3
The advantage is fine tuning the preload. Zero concern running the forks differently. In some off-road bike setups one fork controls compression and other rebound.
Compare this also to the newer HD premium shock set, where one side/shock has the preload/sag, and the other side does the dampening and has that adjustment.
I believe the newer front fork inserts (Axeos or Legends or ??) are setup this way, but I might be mistaken.
Old Jun 26, 2018 | 05:17 PM
  #42
MikeTD3's Avatar
MikeTD3
Originally Posted by pjb
did you first try it with 1 each, or 2 each? If so, what were your impressions?
I didn't, I read all the threads I could find and guessed I would prefer a firmer ride, but at my weight 2 clips sounded too stiff. My setup is stiff and only feels harsh on square edge bumps. For the money they are worth it to me, but if I keep the bike much longer I will probably try the Axeo's.
Old Jun 26, 2018 | 05:41 PM
  #43
HM_SanDiego
That is a fairly considerable dearl you would be undertaking - trying 1 or 2 clips - with the the thought of having to completely dissemble your front forks to make a change. I would not want to do that if I were doing the work myself, and I sure wouldn’t want to pay to have that done twice.
Old Jun 30, 2018 | 02:56 PM
  #44
sanman4ever's Avatar
sanman4ever
Originally Posted by OZARKTOAD
I’m planning on tackling it today.
Any update? 1 or 2 clips? How's the ride?
Old Jun 30, 2018 | 06:36 PM
  #45
Boris04's Avatar
Boris04
Stage I
I put 2 clips in on my winter install, It's ok,but it is a bit stiff on rough roads. Not sure yet at this time that I may pull one out of each side next winter or not. I go 250#, I haven't really notice it better with a passanger.
Old Jul 2, 2018 | 09:43 AM
  #46
2013_FLHTK's Avatar
2013_FLHTK
Originally Posted by sanman4ever
What do you recommend?
Sorry about the delay but I just read the post. I'm going to Ohlins over the winter. Ohlins would have been my pick from day one but they were not available.
Old Jul 4, 2018 | 08:15 PM
  #47
UltraClassic415's Avatar
UltraClassic415
3rd Gear
might be a no so smart question but any down side with no clips installed ?
Old Jul 7, 2018 | 10:07 PM
  #48
OZARKTOAD's Avatar
OZARKTOAD
Finally got it back together. It was a monster. Only real issue was torquing bottom screw as that whole mess spun inside..
Ride is much more responsive/sporty than before. Before squishy ride/now much stiffer. I used 2 clips. Weight 200 alone. I am going to ride it for another thousand miles before I make a decision on whether they are too harsh. My wife and I mostly ride together and I haven’t had a chance to get her on for the test as together we are around 330lb. For the money these were the best option available. If I am disappointed after a couple thousand, I’m still open for someone to sponser the toady with some axeos for a non biased review! . Thanks for all the input! I mentioned the 2 and 1 clip thing to the progressive tech and he said “why the ... would he do that?” Lol
Old Jul 7, 2018 | 10:11 PM
  #49
OZARKTOAD's Avatar
OZARKTOAD
since I did it myself I decided to go with two...my reasoning was if I’d done that work with one...well I’d always wonder what two felt like. Go extreme and then make up my mind if I needed to go down. At this time I don’t feel it necessary as I’m hoping after a thousand it will loose up. If not I’ll go back in next year and take a clip out or review some axeos.
  #50
sanman4ever
Call tomorrow and ask a different progressive tech. Don't be so sure you'll get the same answer, lol
