J&s bottle jack failure
Old Nov 29, 2023 | 05:56 AM
  #51
jake24lt's Avatar
jake24lt
Originally Posted by amarzano17
Just putting the information out there in case someone might need it.
It's $19 for the kit.. I told the gentlemen that I would try replacing the seals and if that didn't work, be back for the $59 jack.
I suspect my problem is the $8 release valve seal, so might try that first and then the full kit if that doesn't work.
It's not that messy, I have changed and refilled the jack oil before. It only holds about half a cup of oil, so not too bad. The recommended
oil seems to be:
Bar's Leaks Jack Oil with Stop Leak - 12.5 oz
$5.88 on Amazon
I will let you all know how it works out once it gets here. I did see it shipped from SoCal today.
Sounds like the ole " add a little brake fluid to the oil " trick. Swells up the seals.
Old Nov 29, 2023 | 06:00 AM
  #52
M Oclaf's Avatar
M Oclaf
Does that still work?
Old Nov 29, 2023 | 09:40 AM
  #53
hattitude's Avatar
hattitude
I don't know about "brake fluid to the oil", but I'll bet some sawdust in the worn out transmission still works.....
Old Nov 29, 2023 | 04:56 PM
  #54
Rob175's Avatar
Rob175
So, now with the new fluid ($5.88) and the kit and the valve seal the repair parts are now up to $33. A NEW bottle jack (Sunex) can be bought at Home Depot for $38.......so what sense does it make to try to "repair" the old bottle jack?? Makes no sense to me.
Old Nov 30, 2023 | 07:12 AM
  #55
ThePaintPirate's Avatar
ThePaintPirate
I've been using the Sunex bottle this summer and has been working somewhat fine. I often have to open the valve and pump a few times to get the jack to work, not a big deal but annoying. This weekend when I was rebuilding the forks on my dyna, I had to force the plunger back down to bleed the air out of it and then pump it back up to get the bike off the lift.
Old Nov 30, 2023 | 05:55 PM
  #56
amarzano17's Avatar
amarzano17
Well it's $19 + $5.88, so $24.88. But yes you can buy a new bottle jack as another approach.
As most of you may know there is some maintenance suggested for these jacks that entails a periodic oil change.
Kit should be here tomorrow.
Unclescarhead
Jan 10, 2019 12:47 PM
slowrollin
Oct 12, 2016 07:13 AM
rhinoWErX
May 24, 2011 10:19 AM
pachowder
May 17, 2009 11:34 AM
SeaHag
Jul 26, 2007 02:15 PM
